Motherboard memory slots
I have 4 slots for memory, at present I am using 2 slots, 1 gig each. The other 2 slots are the same size but are a different color, why is this?
super dave, (ie; big dave) supg59atattdotnet :)
  • supg59 Dec 22, 2008
    does this mean i can add an additional 2 gig of memeroy?
  • supg59 Dec 27, 2008
    thanks......................., dave
    President:
  • 1,179 Answers
Alot of motherboard manufacturers use different colors to identify between banks 1,2 and banks 3,4. Hope this helps.
Posted on Dec 21, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 22, 2008
    Yes as long as it's the same type/speed as what you already have installed. If you try to mix RAM it will make the faster RAM run at the speed of the slowest chip you have installed. That would defeat the purpose of buying faster RAM. Hope this helps.
Bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
put it in an open memory slot although its recommended to add it for an even amount of memory (ie. 2, 4, 6, 8) if im not mistaken 4 slots w/ 8Gb max memory
go here: http://www.crucial.com/, and make sure all is compatible, with free memory scanner(it is safe i have used it and got no viruses)
Oct 31, 2012 | Computers & Internet
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Can i fit 4 gig ram to acer eg31m motherboard?
Yes the maximum memeory is 4 gig. That would be a 2 gig in each slot. Research is saying the memory should be DDR-2 PC2-5300 667MHz chips.
Apr 11, 2012 | Acer Computers & Internet
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your...
put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
Nov 09, 2010 | MSI P965 Platinum (7238010) Motherboard
Memory upgrade
THIS MAY BE A BOIS PROBLEM, THE SOFTWARE OPERATIONAL SYSTEM WILL ONLY ALLOW TWO 2 SLOTS TO WORK IN THE MEMORY CONFIGURATION, EVEN THROUGH YOU HAVE 4 BANKS, MOST LIKELY 2 BANKS WITH THE MAXIMUIN MEMORY OF 2GB PER SLOT FOR THE TOTOAL OF 4GB OF RAM NOT 4 SINGLE 1GB CHIP SETS. YOU SHOULD TRY IT.
ROD
Feb 10, 2009 | ASUS P4P800SE Motherboard
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Memory
Yes you can use 1 stick of 2 GIG of RAM for this motherboard, because your motherboard supports up to 2 GIG RAM...
Hope that helps..........
Aug 11, 2008 | AOpen MX4LR (91.89Y10.002) Motherboard
2 much memory?
First make sure your motherboard can handle the size memory stick you are attempting to install, find out the Max amount of RAM the board can handle per slot. If you are within the range then do a memory test after it is installed to see if the memory is good or has issues. Check out http://www.memtest86.com/ for a bootable memory test program.
Jul 10, 2008 | Computers & Internet
Ram upgrade
It's generally not a good idea to mix sizes as your more likely to get problems, but that said it probably should still work it's most likely your configuration consult your motherboard book as to what order you should install the memory you have.
Oct 30, 2007 | Intel Motherboard
Computers & Internet Logo
375 people viewed this question
David Payne
David Payne
