Question about HP Pavilion a1710n (RK573AA#ABA) PC Desktop
Dvd/cd audio plug and or wire
I have this computer some one has gutted and I dont know were to plug in or what kind of wire to use for it. I have tried to look at my dell and it is kind of a different animal. Ram, hard drive and burner has been removed all I can see that is missing is the audio wire to the dvd cd writer. I just dont know were to plug it in on the mother board. There is one three prong plug with white clip but,there is a group of blue,yellow ,white and black,pluges that are grouped together and are the same shape. Kind of lost on this one. I guess you can tell that Im a novice at this but am learning every day. Thanks for you help. RoyBoy
  • 5 more comments
  • royboysjoys Dec 14, 2008
    mother board # is ABM2ZN-LA
    I also noticed that the pluges that go into the dvd there is a black very thin plug as well. could that be the wire needed for sound. There is two of them in line for to players ans the extra wire got to the other black plug then in to wire bundle. ?? There is three white pluges and two very thin black puges all in the same wire stran that go towards the players..
    RK573AA
    You have helped my very much I dont have a sata drive player so I guess Ill have to go and buy one I have the other wire but I dont see any place to pluge it into. Ill take some pics and get back to you have to run to the store.
  • royboysjoys Dec 29, 2008
    Thanks for all your help. You all are great
  • Rob Liszi
    Rob Liszi May 11, 2010
    I have same issue: It is not one of the cabels posted above. I think it is suppose to be pluges into a sound card, but not sure..
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    If there is no layout on the inside of the computer's side panel, try to get a model number off of the motherboard. That would help greatly. Comment back.
    Problem Solver:
I found the specifications to the computer and it said I am to get a sata hard drive and a sata cd/dvd burner So i guess I better save me some money. Oh and I have to get DDR 2 4200 (533 MHZ) DDR2 or PC2 5300 (667 MHZ) DDR2. Thanks for all you help. Im learning this as I go. I will send more people with questions to this sight, you ahve been a very good informer of good information. Thanks again..Royboy
Posted on Dec 15, 2008
    President:
  • 1,901 Answers
Here is a link from HP for your motherboard:
A8N2N-LA Motherboard
Is the DVD drive a SATA drive? That is, does it have a small (approx. 3/4") connection next to the power connector or does it have an IDE 40 pin connector? If it is a SATA drive, you do not need an audio cable connection.
SATA Picture:
dvd/cd audio plug and or wire - 685c734.jpg
Posted on Dec 14, 2008
  • Wayne Mineard
    Wayne Mineard Dec 14, 2008
    If you have an IDE connection, you may need a cable connection like this:
    This would plug into the connection to the left of the IDE connection and plug into the Audio jack at the bottom left of the motherboard.
  • Wayne Mineard
    Wayne Mineard Dec 15, 2008
    You may not need an audio cable. I am assuming then that the drive is an IDE drive. Connections are made with this type of cable:
    The connection is made using the connectors to the right of the SATA connectors in the lower right of your MB. Try connecting without an audio cable. You may not need one.
Cdvd rom dont work on emachine, will a usb 2.0 external dvd rom drive work
If it is USB CD_Drive you can plug it in a USB port of the computer. You may have to install drivers, but usually Windows Update can download them from the Internet.
Apr 07, 2013 | E-Machines emachines (emachinees) CD-ROM...
No power Pyle PLDN74BTI
Is your power cord plugged in? Are you using a power strip extension cord, if so check it to see if the power surge button hasn't been tripped. If so reset it. See if your wall outlet is working by plugging something else into it. If not working reset your breaker.
Oct 06, 2012 | Pyle PLDN74BTI 7 Double DIN TFT Touch...
I have a problem with my speakers and i can'nt hear any sound from my computer and i don't know what kind of speakers have adjuts with my computer
click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
you might need to select stereo speakers
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps you
Aug 20, 2011 | Logitech LS-21 2.1 Speakers
I have a lg cd/dvd burner, supermulti. How do i find out if it supports cd&g burning or copying karaoke discs? I dont know a model number, its internal.
if its a cd/dvd burner it will depend on which burning sofware you are using some will support burning media files and dvd's some will not you could search the internet for some free ones if you do not have any of this software cnetdownload.com also majorgeeks have lots of this free software
i will attach some links you could try if they dont suit your needs just uninstall them
http://www.nero.com/eng/downloads-nbl-free.php
http://www.majorgeeks.com/BurnAware_Free_d5839.html
http://www.majorgeeks.com/CDBurnerXP_d4242.html
http://www.majorgeeks.com/ImgBurn_d4870.html
http://www.majorgeeks.com/ShrinkTo5_d4755.html a dvd copying program
http://download.cnet.com/free-easy-cd-dvd/3000-2646_4-10627009.html
http://download.cnet.com/active-iso-burner/3000-2646_4-10602452.html
http://download.cnet.com/instant-cd-dvd-burner/3000-2646_4-10393316.html
Burn audio, video, and data CDs/DVDs and create and burn ISO files. Instant CD & DVD Burner is the ideal choice for anyone looking for a simple but full featured CD/DVD burner. Build and burn ISO files on the fly and compile all kinds of audio, video, and data CDs and DVDs from any kind of file (MP3, WAV, AVI, MPEG, DIVX, XVID). Instant CD & DVD Burner supports all major drives including CD-R, CD-RW, DVD-R, DVD+R, DVD-RW, DVD+RW, and DVD-RAM (SCSI, IDE, EIDE, and USB 1.0 and 2.0).
hope this helps
Apr 17, 2011 | LG Computers & Internet
My cd-rw/dvd rom burner is very successfuly to burn any kind of blank cd. The problem is : fail to read any kind of data from every common blank cd after burning. It's just only can read successfuly cd...
Have you taken a CD that you have burned to another computer, to see if the other computer can read the CD?
Rather than spending $50 to $75 to have a qualified computer technician try to trouble-shoot the problem, spend $40 to $50 to buy a brand-new CD/DVD reader/writer.
Aug 05, 2010 | ASUS QuieTrack CB-5216AG CD-RW/DVD-ROM...
Loose wire
Delva,
This is the cd audio cable most people currently do not need this cable. It connects on your motherboard to the back of your Optical drive (CD or DVD).
The purpose of this cable is for play CD's in you optical drive and it sends the audio DIRECT to the sound card rather than piping it through the data cable and then redirected to the audio sub system. Its kind of like having a short cut to the sound card but is only used if you play CD audio disc in your CD/DVD. MP3's and other data are still sent through the data cable.
Hopefully you found this useful
Dave
Nov 18, 2008 | Intel Motherboard
Audio wire
kindly indicate here also the type/model of motherboard do you have there...
Jun 07, 2008 | AOpen COM4012 (90.4FD37.001) CD-RW/DVD-ROM...
Cable on hp pavilion 7800
If it is stripe cable about 3CM long it is the IDE cable (simply called it data cable)...other than that another smaller cable sometimes may be fixed without the power cable
Thats should is the audio cable...previous operating system (like 98) didn't recieve audio signals without that cable..but you dont need it now with XP..
The three cables are the POWER, IDE and the AUDIO
Apr 30, 2008 | Computers & Internet
HP Pavilion a1710n (RK573AA#ABA) PC Desktop Logo
998 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
