Our tv just shut off
Im trying to get help for my phillips hdtv because although it needed the color fixed it still worked until today when we dropped our remote and the tv just shut off. Did a breaker go out, what happened
    Genius:
  • 1,199 Answers
This sounds to me like the flyback unit on the main board has burnt out (part is around $ 70.00) Warning have a pro do it HIGH VOLTAGE AREA
Hope this he;ps ya!
Posted on Dec 14, 2008
Phillips HDTV turns off when we turn the XBOX 360 on.
More than likely this is a trigger from the HDMI cable which can be disabled in the tv or xbox settings. To check, hook the xbox up to the tv with RCA cable that is supplied with the xbox and see does it turn the tv off it probably wont happen when connected like so.
Jan 08, 2015 | Philips Phillips 40 in. LCD HDTV
The tv shuts shuts off by itself and wont come back on until next day, do you know what causes this
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 06, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
My tv does not show any image and shuts off by itself
Solutions?
Hope this helps
May 21, 2010 | Akai LCT3785TA 37 in. LCD HDTV
The tv picture vanishes and there is multi-colored lines on the screen for a second then shuts off and then will turn itself right back on and it will keep doing this
Solutions?
Hope this helps
Mar 20, 2010 | Samsung LN46A650 46 in. LCD HDTV
Getting a No Sync message on my television
Solutions?
Hope this helps
Jul 12, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Phillips HDTV Projection TV. Colors don't line up create shadow
yes sounds like a convergence issue. The following link has convergence repair kits which contain the parts and a cd with instructions on how to do the repair.
http://www.tvrepairkits.net/
Jul 10, 2009 | Televison & Video
TV sound goes in and out, it's a Phillips brand
poor signal coming in from antenna or cable will cause sound drop. but usaully the color goes first.
try another source like a vcr or DVD player and see if that is stable ...if same trouble your sound circuits need looking at.. which are easiest to fix.
Oct 21, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
TV shuts off by itself!
Solutions?
Hope this helps
May 26, 2008 | LG 37LC7D 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
