Question about GE WJSR2070B Top Load Washer
The 13/16 nut that holds the tub down keeps falling off
The 13/16 nut that holds the tub down keeps coming loose i have tried everything to keep it tightened what could be done to help me solve this problem , after i tightened it the first time it worked but it started making a loud noise
II suspect it is bad design, imagine that. We are having the same problem. After replacing the nut and using lock tight on threads, it worked two days and loosened again. My next attempt will be to "stake" the nut in place. This involves using a chisel and hammer to lock the nut in place by deforming the nut and shaft with a 90 degree dent. A second alternative will be to drill and install an allen head screw to lock shaft threads to nut.
Posted on Jan 04, 2009
LT2000 craftman mower bolt and nut that tightens blades keep coming loose
Get some red lock tight and put it on the spindle shaft threads. Sounds like the threads are worn down and just won't hold the spindle nut tight any longer.
Jul 02, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
CRANK SET KEEPS COMING LOOSE
You may try using a lock nut which may stay put. You can find lock nuts at hardware stores or Lowes, etc.
Apr 30, 2014 | Best Fitness BFSB10 Indoor Cycling Trainer
The base keeps coming boose. i keep tightening and
If you just need to keep the nut from coming loose, try LocTite Blue (assuming metal thread and nut). You should be able to buy it at the local hardware store.
I had the same problem with a slightly different Price Pfister model sink. My problem was primarily because the sink basin was thin and not "beefy" enough to support the faucet. The whole thing would flex because the metal was thin and the nut would come loose.
Using wood for reinforcement down there is a bad idea (it would get wet and rot). So, plastic was the way to go.
I bought an inexpensive piece of plexiglass/lexan at the local home improvement store. A cheap plastic cutting board would work well too.
I cut a rectangle that was a couple inches wider than the the faucet holes and that would fit underneath the sink basin where the holes for the faucet were.
I marked the holes and cut them with a hole saw (Go slow, the heat from the hole saw will melt the plexi!). Cutting slightly oversize makes everything fit easier.
I put my new "reinforcing washer" in place and tightened everything down. The nut snugs up nicely against the plastic and after four months: no more flex, no more nut loosening.
Jun 13, 2010 | Price Pfister Marielle Kitchen Faucet with...
My 2003 oldsmobile silhouette front wiper blades have stoped working several times. The screw that holds the wiper arm to the motor keeps coming loose. Is there anything that will help. We have replaced...
You can replace the nut with a locking style nut. Your local hardware store should be able to provide you with one.
You can also purchace a small tube of "lock-tight" (brand name) that you apply to the threads then tighten the nut. Once the lock tight has dried, the nut will not come loose.
Good luck.
Mar 15, 2010 | 2003 Oldsmobile Silhouette
Our kenmore elite washer makes a loud loud noise when spinning and the tub has alot of play from side to side when not running. Does this maching have a nut on the bottom holding the tub in place?
You can remove the agitator to see if it has a nut holding the tub on, but from what you are saying the transmission bearings are worn out. Loud noise and side to side play would indicate this. If the agitator does come off you can see if it has a nut that will tighten the tub down. I have never seen one as most are all one section tub to transmission. Keep me posted on what you find.
Sincerely,
Shastalaker7
Feb 04, 2010 | Washing Machines
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
Big nut that holds tub and agitator in place keeps coming loose
Try to put some red thread lock on it. Red is permanent and blue is not permanent. I would use the red if you do not need to take apart again.
Good Luck
Dec 29, 2008 | Washing Machines
SMEG Grill Element Screw Falls Out
there may have been a nut welded in the roof that has worked itself loose,or more likely you have stripped the thread.
try using a self-tapping screw to hold it in place
Dec 23, 2008 | Smeg A42-5 Dual Fuel (Electric and Gas)...
GE WJSR2070B Top Load Washer Logo
127 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
