Question about Canon Elura 90 Mini DV Digital Camcorder
Canon elura 90: won't load tapes
I tried to rewind a tape that was in the camera, heard a loud sound and then the message eject tape came on. I tried to load another tape and it won't go down. It tries to engage and then ejects the tape.
Previously, the camera was on the card mode. I changed to video tape mode and still it does not engage the tapes.
  • 586 Answers
    Actueally the loading section of the camera is mechanically unstable.And it needs mechanical adjustment.A sensor is present in its loading section that provide information of the presence of the tape in this section,When the mech. get unstable the  sensor disfunctons.
    Therefore,In short,Your camera needs mechanical adjustment.For this please contact any expert nearby to solve this.
  Thanks for using fixya.
Posted on Dec 14, 2008
    Scholar:
  • 61 Answers
Make sure the power is on this unit and you are pluged into a good source of power. The disk tray needs power to lower. A lot of tapes get loose in there case and need to be fast forwarded and then rewound completely in order to help spool them properly in their case. And what you are experiencing sounds a lot like this. It is also possible that you need to buy a head cleaning unit for your elura and run it in the camera for 10 secs and then try again. (Did you try this with a New tape? or just used ones?) We bought a small tape rewinding unit for around 39 dollars that helps us to rewind the mini DV tapes without adding wear and tear on our camera and it seems to help with the issue of loose tapes in the camera getting rejected as they won't wrap around the tape head as nice.
I have a Canon Elura 85 camcorder and the tape won't eject and will the tape will not play, rewind, etc. I'm getting a "Change Cassette" error on the screen with a beeping. HELP.
This can be caused by several problems including a defective eject switch in the cameras internal circuitry, a stripped gear or a bad motor. This will require disassembling the camera to diagnose and repair. This can usually be done fairly inexpensively but it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 24, 2011 | Canon Elura 85 DV Digital Camcorder
Tape will not eject
Hi, The tape sounds to have undone inside your machine, be careful if its important home video etc. Try use a blunt kitchen knife to prise it open, the camera drawers are stronger than they look, this worked for me. Thanks
Mark
May 03, 2010 | Canon Elura 90 Mini DV Digital Camcorder
My Canonc Elura 40 seems to bind / twist the tape during rewind. This has happened to three varieties / manufacturers tape.
It's the camera itself, it needs some fine tuning. I'd recommend finding a local camera repair shop before throwing in the towel on this one.
Dec 05, 2009 | Canon Elura 40MC Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
Canon Elura 65 Camcorder Refuses to Load Mini DV Tape
Try a different tape in case the take up isn't working in the previous tape.
Clean the tape heads with a tape cleaner in case there is buildup on the pinch rollers causing the tape to jam or slip.
If those solutions don't work, you should take it into a repair shop to have a closeup view as to what the problem is unless you see something obvious like a spring broken or loose or a bent piece or foriegn objects in the deck.
Aug 12, 2008 | Canon Elura 65 Mini DV Digital Camcorder
Canon Elura 100 won't eject tape
I have been having the similar problem. Try switching the power to off and then eject the tape in the off position. My finally ejected.
Apr 04, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 60-wont load mini dv
mine just won't load the tape. mechanism closes fine when I take the tape away and try door. sits there until I do.
Mar 30, 2008 | Canon Elura 60 Mini DV Digital Camcorder
Error MSG when rewnding
that's my problem too. I'm going to try the solutions for the "remove tape" problem when trying to record--use dry head cleaner and the other options, check out that thread,
Feb 21, 2008 | Canon Elura 100 Mini DV Digital Camcorder
Remove The Casette Message
THESE CAMERAS ARE PEICES OF ****!!!!!!!!!!!!!!!!!!
I suggest that no body buys from cannon again!!
I am suppose to record my sister-in laws wedding and BOTH of my ELURA 100's are displaying the EJACT TAPE message!
"TEMP. FIX"
This takes pateince however for me it works....When you get the EJECT TAPE mesage....eject the battery with the power on (thus the power will go off by means of the battery not being in camera) then slap the battery back in....and KEEP doing this untill eventually the camera will NOT DISPLAY the message and actual work.
It may take up to 20 trys ....slap it in..slap it out...slap it in slap it out...BUt for me it works.
If it appears to work but as you hit the RECORD button it beeps and displays the EJECT tape message again...Go back and eject the battery again and repeat the STEPS...but dont worry , that means your getting closer to it working.. LOL
P.s- I hate CANON
Sep 23, 2007 | Canon Elura 100 Mini DV Digital Camcorder
Canon Elura 90 Mini DV Digital Camcorder Logo
443 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
