Question about Reddy R60A Utility Heater
My Reddy Heater runs a little then shuts off
The heater is a Reddy 60K BTU HSI Model # R60. I run K1 Kersosene. The was bought new and I've had it for about 6 yrs. I run it in my wood shop a very dusty invironment. I have never done any maintenance so I know I'm over due, but I don't have a clue as to how to go about this job. I don't know if there are any manuals on the market that can walk you though tuning up this heater, sure would like to have one. Thanks for any help you can provide.
Bill
  • Bill Range
    Bill Range Dec 14, 2008
    This unit to my knowledge doesn't have a thermostat.
Before I went replacing anything, I'd open the right access (looking from the front)panel. Pull the black feed hose off of the nipple on the the filter assembly. Carefully remove the filter barrel, which will be sticking down in the kerosene tank drawing the fuel out.With a flat tip screwdriver, rotate the plastic piece on the bottom of this assembly. Mine is red and looks like a little plug with a screen filter, shaped like a funnel. It has a friction fit so it will not be threaded. Pull this out and see if the fliter has dirt or debris in it. Blow it out with compressed air or wash it with a solvent. Replace the filter and reassemble, plug it in and turn it on. 98% of my early shut down or fuel issues are resolved by doing this. Doesn't take much to restrict fuel flow in these heaters enough to shut them down. Good luck.
Posted on Dec 13, 2011
  • Reddy Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101 ...
Posted on Oct 31, 2010
    Genius:
  • 1,199 Answers
It sounds like you need to replace the thermostat in the unit! ( avery common problem in this model!
I hope i was if help!
Posted on Dec 14, 2008
Reddy-Heater will start then run about 10 seconds then stop.
The heater has a photocell that has to see the correct flame or it will cause the heater to turn the unit off.
I would suggest checking the the pump pressure and the output filter to make sure you are getting the correct amount of pump pressure to the nozzle.
Here is a link to the actual service manual.
http://www.desaparts.com/hsi.html
Oct 08, 2012 | Reddy HEATER RH170T 165,000-BTU PORTABLE...
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Mar 09, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy R60A Utility Heater Logo
429 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
