Question about Schwinn 430 Elliptical Trainer
NOISEY SCHWINN 430 ELLIPTICAL
NEW STARTED SQUEEKING 20 MINUTES FIRST USE VERY LOUD
  • Anonymous Jan 07, 2009
    I had the same problem. The noise was coming from the handle bar pivot. I tried teflon and lithium grease, but neither solved the problem. It turned out the handle bar pivot rod was slightly too short which presses the plastic bearings together so hard it would start to squeak. Loosening the bolts on the handle bar pivot fixed the problem. In the end I added a washer to the end of the bar to make it seem longer. Then I was able to tighten down the bolts and it's been quiet ever since. I explain this in my review on amazon.com, Name is Dave Krueger.
    Problem Solver:
  • 13 Answers
Hi I'm Ryan, do you know where it is squeeking from? if you can find the squeek try 3 in 1 oil that should stop it.
Posted on Dec 31, 2008
I solved the problem by the following: take all the joints apart and grease with white lithium grease. Don't put them back together too tight! Don't take the little rollers apart; they're too hard to get back together. Just spray the whole area with silicone spray. Here's the real fix: our flywheel cover (and i guess the whole flywheel assembly) was loose. Take the half dollar-size black cover off the center of the flywheel. Tighten the nut inside. You need a socket wrench; you can't do it with the multi-wrench provided. The 'Cruiser' is much queter now! Good Luck, David
Posted on Jan 04, 2010
My Schwinn 430 elliptical makes a clunking noise when pedalling backwards but not forward. What is causing this?
I have a iron man cdt elliptical that was clunking . I found a shaft on the end of the crank was slipping in and out, inside the bearings. I shimmed it and retightened the retaining washer which prevented it from slipping . Smooth as silk now. It was very frustrating because all seemed tight at first.
Nov 10, 2012 | Schwinn 430 Elliptical Trainer
Need manual for schwinn personal trainer 405 tread mill
Hello Brend
Please download the assembly manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/AM/Schwinn/SCH_430_AM_RevB_web.pdf
Please download the owners manual for Schwinn® 430 Elliptical from the link provided below :
http://download.dfxi.com/supportdocs/OM/Schwinn/SCH_430_OM_RevA_web.pdf
Oct 10, 2011 | Schwinn 430 Elliptical Trainer
The power cord for my schwinn 430 elliptical no longer stays plugged into the machine. I have to push it really had into the bike outlet so the machine turns on, but as soon as I take my hand off of it,...
Do you think the power cord is going bad? If so here is the parts list for the Schwinn 430 if you need to order a new AC adaptor. If you think the connection inside the machine is going bad you may want to find a servicer to look at it.
Apr 19, 2011 | Schwinn 430 Elliptical Trainer
What is the output of the ac adapter for the schwinn 430 elliptical???
It should be at the bottom of the machine in the front facing away from you if you are on it.
Nov 02, 2010 | Schwinn 430 Elliptical Trainer
During use, the speed goes to zero on the panel and then a couple minutes later, it shuts off....Schwinn 430 elliptical.
sounds like the sensor is loose or bad.I have the same schwinn 430 elliptical and my speed stayed at zero and after a couple minutes it would shut down.i called schwinn bowflex and they sent me a new sensor ($2.00)since my warranty expired and i installed it(not fun) and thats what fixed it. im back to working out.
Jul 10, 2010 | Schwinn 430 Elliptical Trainer
Where do you put a battery in a schwinn airdynne
To install new AA batteries just pop the battery door in the back of the computer
Apr 05, 2010 | Schwinn 430 Elliptical Trainer
Schwinn 418 Computer does not come on.
Did you ever fix this? I am having the same problem...
Dec 10, 2009 | Schwinn 430 Elliptical Trainer
Need to replace the drive belt on my Schwinn 430 Elliptical
http://download.dfxi.com/supportdocs/SM/Schwinn/SCH_430_431_450_SM_RevC_web.pdf
Follow this link for step by step instructions. Note you will need a crank puller which you can purchase at most bike shops. remove both covers then crank weldment(discs).
Jan 19, 2009 | Schwinn 430 Elliptical Trainer
Schwinn 430 Elliptical Trainer Logo
1,633 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
