Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
When I restart my computer (vista) it does not reboot with my external hard drives plugged in.
    Scholar:
  • 40 Answers
Most likely your BIOS is set to search for bootable external drives/devices. This causes the computer to pause indefinitely.
To fix this, you will need to change your BIOS boot settings.
It is simple enough and danger free so long as you make sure you keep your harddrive as a bootable device.
To fix:
1> Enter the BIOS by restarting the computer and waiting for a display to show up before windows starts - it will either be a graphical display or text, but should say "press F8" to enter BIOS. I use F8 merely as an example, as that is what mine uses - it can be different for you.
1.1>If you cannot see it quickly enough, simply press the "Pause" button on the keyboard - this will cause the boot process to stop until you press another key, and will allow you to see which key is required to be pressed to enter the BIOS.
2> Since I do not know what BIOS or motherboard you are using, I cannot give exact names for what you will need to navigate to in order to find the settings, but in general it will be BIOS Features, Advanced BIOS features, etc.
2.1*> In Award BIOS it will be under Advanced BIOS Features.
2.2*> Whatever category they fall under, they will be named something like "First boot device" "Second boot device" "Third boot device" etc, and possibly "Boot Other Device" or "LAN BOOT" etc.
2.3> Once you have found these settings, DO NOT change the setting which has a value of "Hard drive" or "HDD." If it has settings named "Boot from USB" "Boot Other Device" or something along the lines of "Third boot device: USB" then you should disable those. Anything relating to Boot and which are not CD/DVD or HDD/hard disk should be set to "Disabled" or "None."
2.4*> These changes can be reversed any time, and any mistakes with the booting priority can be fixed by simply reversing the settings (the BIOS will probably allow you to set everything to Default and that ought to fix it if anything is messed uo as well.)
3> Hit Esc to get out of the category and navigate over to "Save and Exit Setup." This will save the changes and restart the computer.
4> Your problem should be fixed, and USB devices plugged in during reboot should not effect the boot process. However, if the problem continues, please reply that it did not work and I will move on to the next possibility.
3>
Posted on Dec 15, 2008
  • Dshack
    Dshack Dec 16, 2008
    You've cross-posted your request. I'm linking the other post since I'm unsure of which is the most recent, or which I should respond to.
    Here.
Missing or corrupted system 32 wont install off windows xp disk
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
Mar 13, 2017 | Compaq Mini 110c-1001NR Notebook
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
The device is simply plugged into a USB port on your computer as you would connect a flash drive.
Unlike a flash drive, however, a USB hard drive can store a much larger amount of data.
If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely.
Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7).
The USB device should be listed as "removable disk" once it is plugged into the computer.
If it is not listed among the available drives on your computer, proceed to the next step.
Ensure that the data cable is working properly.
Try another USB cable if you have one available.
Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive.
Reboot the computer if the USB hard drive is still not recognized.
Plug the USB cable into another USB port and check to see if the device is detected.
If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port.
If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem.
Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager."
For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter."
Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives."
If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears.
The external hard drive may have been detected but the device is not working properly.
If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced.
Hope this helps
Nov 07, 2012 | Computers & Internet
Windows xp will not restart with usb plugged in. I am running windows xp sp2 with a Hitachi 500g external hardrive that is designed to turn on and off with the computer. The same hard drive works fine on a...
Sir, your PC might have been checking for external devices which plugged in to boot from. Thats wrong. So get into the bios of your computer while startup and change the 1st boot device to your computer's hard disk. And its a bad idea, starting your computer with a usb device plugged in.
Jun 29, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
My external hd Trascend 500 gb was recognized on start windows vista bussines on USB2. But after few minutes he became unstable not recognized after that again recognized and again
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 18, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Can not stop generic voluem right now.....hard drive
Just restart your computer, and disconnect the MyBook as your computer _starts_ to reboot.
May 28, 2010 | Western Digital 500GB My Book World...
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
I am running vista home ultimate. i have a hard drive from an XP laptop that I put in an enclosure to access it with the vista computer. the vista computer says that install failed every time i plug it...
If ou want to save your file you have to plug the into a xp machine, pulled the files off and burn them to a dvd or cd. Then you plug it into the vista, and let vista format the drive. Your enclose hard drive have windows xp boot files, and they need to be formatted before plugging into the vista. Vista is thinking it is a bootable drive where it is not.
Aug 11, 2009 | Fujitsu Computers & Internet
Not accesible
hi there, i to have an iomega external drive, have you tried to disconnect the cable, i.e.. the usb cord and restarting the computer and pluging in the hard drive itself back into the usb slot.....if yes i am thinking, another thing is, wha operating system are you using, if it is vista and you restarted the computer with it pluged in you must restart it without the iomega plugged into the computer, when an external drive is plugged in and the system resatrts vista recognizes it as an internal drive and tries to reboot from it....i am not sure why vista does this, it happens to me and microsoft says it's a protection thing, from hacker hardware components......so all usb things should be replugged into the computer after vista has started with just the regular things...microphones and such are ok....just things with mass storage are what need to be unplugged and replugged into the computer after reboot....hope this helps....shia
May 11, 2009 | Computers & Internet
Freeagent
Turn off computer.  Unplug hard drive from computer port.  Turn on.  uninstall from Add/Remove Hardware in Control Panel.  Reboot computer.  Plug in external hard drive.  Verify Full System functionality in Control Panel, System, Hardware, Device manager.  If nothing is expanded all IS functional.
James Mac
Sep 08, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
260 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
