Question about Samsung SCX 4200 All-In-One Laser Printer
Scanner problem with samsung sck4200 - Samsung SCX 4200 All-In-One Laser Printer
  • Roipatrick Aug 04, 2010
    Good day Sir, Please give more information about your scanning problem so we can determine the condition and also to give you the right solution.
    I want to know if your scanner doesn't work or the unit scans very slow or there's a problem in your copy.
    thanks and God Speed.
Samsung 4200 gives scanner error
there is 3 problems whit SCX 4200 scanner:
1. Defective ribbon cable
2. Defective scanner motor
3. Defective scanner lamp
or
ribbon cable is unplugged - open rear cover to chek this!
For 1,2 and 3 - visit Samsung service
Apr 05, 2011 | Samsung SCX 4200 All-In-One Laser Printer
I have a Samsung SCX4216F It appears the scanning function is not working. Light is not turn on.Blank white paper as a result. I wonder if we could somehow mod the scanner lamp since it is nearly...
First of all you have to clean the scanner optics very well. Don't forget the Little mirror below the scanner. Clean the exposure glass.
I service thousands of these machines and I'm possitivly sure that the problem is damaged interface(grey flat) cable between the scanner lamp and scanner board. It costs not much.
The scanner is the same in following models :
LEXMARK X215, Samsung SCX 4016, Nashuatec DSm516pf and many others
good luck (don't by scanner lamp in any case)
pifonski
Mar 03, 2011 | Samsung SCX-4216F All-In-One Laser Printer
Need samsung scx-4521f scanner driver
Here are the drivers:
Printer: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/SCX-4x21.zip
Scanner: http://downloadcenter.samsung.com/content/DR/200912/20091217112644875/Samsung_SCX-4x21_Scanner.zip
I hope you got the answer. :)
Feb 04, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Hi I have just purchased a Samsung CLX- 3185 Colour printer, scanner and copier and the screen states ' Scanner Locked'
The scanner may have a locking lever that locks the scanner head so you can transport it without damaging the scanner head.
Locate the locking lever and unlock the scanner head.
Jan 23, 2011 | Samsung CLX-3160 All-In-One Laser Printer
Scanner locked - samsung scx4216f
its may be the problem related to its Scanner Cable.
Remove the Scanner cable
Feb 24, 2010 | Samsung SCX-4216F All-In-One Laser Printer
Samsung scx4521f saying scanner locked
under the operations panel, where the copies comes out there is an optic lock. You need to unlock it.
Sep 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Scanner locked on samsung 3160fn- how do I unlock it?
I think you have to call the service. They will change the hole Scanner. Because you can't unlock the scanner by any buttons or mechanical trick!
Mar 23, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-2160N Sanner Locked
Same problem thanks for ignoring guys!
Dec 11, 2007 | Samsung CLX-2160N All-In-One Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
60 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
