Question about Lexmark Office Equipment & Supplies
Have 2 brand new Lexmark Z1380 printers and both have stopped printing saying cartridge is not compatable. It is genuine bought from PC world.
  • Brian Merritt Dec 14, 2008
    Solution did not work - also tried downloading the latest driver - no difference
  • 1,498 Answers
Hi Brian,
Be sure the protective tape was fully removed from the new cartridges.
Several Lexmark models come with short term use cartridges that are different from the replacement cartridges. Be sure the correct cartridge selections are made for both the black and the color options in the change window.
Thanks for using FixYa!
Mike
Posted on Dec 14, 2008
    Master:
  • 479 Answers
After inserting the cartridge it is necessary to select the cartridges.as the printer is not detecting the cartridges which u have installed so its saying non compitable.still if u do not get printout after trying every thing.just uninstall the printer drivers and then reinstall the drivers again it will just take half an hour to do so and the printer will work properly with the same cartridges.this is a common issue .do not worry.will get solved after reinstalling the drivers. thanks.
  • 734 Answers
I think there is sum alignment problem in cartages or might be you do not properly install the cartages.
Thanks
  • Lexmark Master
  • 6,487 Answers
Try first to power off the printer for 5 minutes and remove the cartridges and after 5 minutes put them back in and power on the printer and check if its already working....
    Sergeant:
    Champion:
  • 347 Answers
Hello brian,
Have you cheked that the cartidges are on their correspoodin place? You might have mixed the black and color cartidge.
ALso make sure ther are well fitted into the cartidge holder.
You can also try to unplug it for a copule of minutes and see if that fixes your problem.
Good luck,
Dahaka
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I have a four in one Lexmark x5630 printer and have replaced cartridges with brand new black and colour 36 & 37xl. The printer won't even print a test page - just says that cartridge error co
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Try to contact the store where you bought the new cartridge(s) and have them replace it. You may also contact Lexmark Technical Support Center for assistance (especially if you're using genuine cartridges).
Feb 14, 2012 | Lexmark Office Equipment & Supplies
Cartridge Error .... help!? I've read all the other replies and it's not helped!
Just make sure you are using a genuine Lexmark cartridge and not some remanufactured, refilled or clone cartridges. Please follow the steps below to identify and fix cartridge issues:
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 14, 2012 | Lexmark X4650 InkJet Printer
I have put compatable ink cartridges in my printer and a message comes up
Lexmark does not recommend the use of refilled, re-manufactured or clone cartridges. Not only that you might not get the print quality you expect from ink that is specially formulated by Lexmark but you'll never know if the cartridge will actually work with your printer or harm your printer.
I highly recommend that you replace your compatible cartridges with genuine Lexmark cartridges to get the best printing results.
Nov 14, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Printer doesnt want to print
Is it a genuine Lexmark cartridge? They are sometimes partial to their own products.
Oct 13, 2009 | Lexmark X7350 All-In-One InkJet Printer
Ink level reset button for Lexmark X2690
There really isn't. Lexmark's 'official answer' that I have seen is this:
Genuine Lexmark inks and cartridges are perfectly matched to the printing system to ensure that every document produced is of the highest possible print quality, providing long-term dependable service from your Lexmark printer. Using incompatible inks in an attempt to extend the life of a genuine Lexmark cartridge beyond its recommended usage can cause failures in several different areas of the printer. Any such damage to your printer caused by refilled ink cartridges will not be covered by your Lexmark printer Warranty, Extended Warranty or Service Agreement.
If the error message stopped you from using the refilled cartridges, you shouldn't have damaged the unit in any way.
Steve
Feb 18, 2009 | Lexmark X2690 All-In-One InkJet Printer
Lexmark printer printing blank pages
hello sir,
dont worry this is d simplest case when either cartirage is choked or fileed with duplicate ink.
Try with another and if u still face this prob den reply
abhinav
Jan 10, 2009 | Lexmark Office Equipment & Supplies
Compatable black ink cartridge
Is the print out normal? If the print out is normal you just need to reset the software to know that you have a new cartridge.
If you open the printer cover, remove and then reinsert the cartridge you should have a message on your display asking you to align the cartridge. When you do this it will reset your ink levels.
If you are using a brand new Lexmark cartridge this should work find. If you are using a refilled cartridge then you will still see the cartridge as they are not supported on Lexmark products.
Thanks
Catherine
Sep 09, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 all in one
It is observed in branded printer not only lexmark also with HP printers yoou get this same problem.
It is always recomended to use genuine cartridges rather than refilled or any other brand ink cartridges.
As for HP cartridges they are all made under six sigma process where it is very rare you get a ink cartridge issue.
thats why HP Gives 18 months of replacement warranty on its cartridges
The same applies to Lexmark printers aswell
Make a habit of usig Genuine cartridges which will give value for your money.
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark (Invalid cartridges)
That printer uses Lexmark 32,33,34,35 cartridges. The branded cartridges should work. Have you contacted Lexmark's technical support center? Contact information is on www.lexmark.com. They should be able to get you going again.
Mar 09, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
