Question about Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cycle
  • 1 more comment
  • Anonymous Dec 27, 2008
    My machine started making the same noise after washing a large blanket, which I suspect made the load unbalanced. Now it clangs and knocks at the end of the spin cycle. Sounds like a motorcycle starting up.
  • lasvegasjr Jan 23, 2009
    My washer washes and spins well, except that during the spin cycle it makes a loud noise.
  • Anonymous Jan 25, 2009
    one of the 3 pins in the tubes mounted to the base frame are missing thats all i can see but cant seem to find a picture showing them or a part number model number 110.28812790
  • Kenmore Master
  • 5,568 Answers
Most washer tubs are suspended by heavy rubber O-rings. These do fail with age so that the tub is not being held centered anymore. I suspect one of them has failed or come off during a severely unbalanced load.
Posted on Dec 15, 2008
3 Suggested Answers
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Whirlpool Kenmore 80 Series is making loud noises during washspin
Hi, Make sure the washer is solid to the floor. To level the washer, Put your foot against the front panel at the floor and tip the back of the washer toward you. Then set the washer back down and the rear legs should self adjust.
Hopefully this will stop the washer from shaking.
Vic
Jul 05, 2009 | Washing Machines
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Kenmore makes whining noise as it tries to spin
The drive coupling has probably broken. Usually happens when you overload the machine. Easy fix. READ MORE
Jan 21, 2009 | Kenmore 24902 Top Load Washer
I have a Kenmore series 80 washer that is making a loud clunking
check the motor coupler between the gearcase and motor for wear. If it is cracked or broken it will need to be replaced
Jan 04, 2009 | Kenmore 24032\24036 Top Load Washer
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine
it could be the break above the transmission. it engages what looks like break shoes when the machine is not spinning. if these are worn down to the rivets then it will make this noise. it requires a special tool to replace.0de7df9.jpg
Jul 14, 2008 | Kenmore 23822 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
706 people viewed this question
Sal De
fordexpert
Robert Rankin
