Question about Whirlpool Duet GHW9150P Front Load Washer
Belt on Whirlpool Duet GHW9200LQ is broken
How do you get the new belt on?
  • fkaleta Dec 14, 2008
    My duet shakes a lot during the spinning cycle. We check it to see if it was balance and it is on all sides. What's making it shake?
  • 85 Answers
Install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Posted on Dec 14, 2008
Our Whirlpool Duet GHW9200LQ washer will not always start a cycle when you press the START button, although it does not give any error code. What's wrong?
I also have this problem. I removed the control panel, removed the green start button, put the control back together and pushed the red button on the panel and the washer works again. I just have to replace the start button.
Jan 22, 2013 | Washing Machines
Whirlpool Duet WED9150WW dryer heats up but does not spin. The belt is not broken and door switch appears to be working.
If the dryer is on and everything is working except the drum is not turning, then the motor is bad. Here is the new motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | Whirlpool Duet WED9150WW 6.7 Cu. Ft....
My Whirlpool duet sport makes a terrible noise during spin cycle like drum hitting something or belt slipping. There are no error codes or smell of burning belt. HELP!!
the drum bearings are shot,you need to get them replaced,if the drum is actually hitting the sides if the tub this could be a broken spider thats on the rear of the inner drum that holds the drum on if this comes loose it can cause serious personal injury
May 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My duet washer just stopped spinnig
Your belt is disengaged or broken. You still hear the motor and if you do then it is the belt. Go and open the back panel of the machine and see if you can find out about the belt. Remember to be safe at all times. Good Luck
Jan 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet (Model # WFW8400TW02 )washer stopped working. the steel drum is not rotating and clothes are not getting washed. please let me know what could be the problem.. --Ritu
If this has a belt, then the belt may be broken or stretched out. Bad drum bearings can seize up and won't let the drum rotate anymore. A bad door switch can cause the machine not to run.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Drum will not turn on whirlpool front end load washer when in a cycle, just sits there.
im not competent with the washer you have some use grav forge drive but most are belt driven have a look to see if the belt is broken
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How to replace the belt on a whirlpool duet washer
To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and remove the rear panel.
2. Place the drive belt on the drive motor pulley with the ribbed side on the drive motor pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, please let me know. I hope this helps you.
Sep 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does code F 30 mean on my whirlpool duet steam washer WFW109700VW?
This error relates to the motor drive. Plug off the wall, open up behind, look for broken belt. If the belt is good its the motor brushes. Secure connections to the motor, look for loose wires.....
Good luck
Sep 27, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool duet broken belt
Hi, Belt Part # 8181670 The rear panel will need to be removed and you can access the belt. Make sure the belt is centered in the middle of the large puley. Once the belt is replaced, plug the washer back in and let it spin for a short period of time to be sure the belt will stay on.
please let me know if I have helped you at all or if I can assist you further.
Thanks
Vic
Jul 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
187 people viewed this question
Dan Webster
Dan Webster
Sal De
