Question about Philips 60PW9363 60" Rear Projection Television
Philips 60 Hi, thanks for your help. I found a cable at Radio Shack with DVI on one end and HDMI connection on the other end. The 12ft. cable was $50. I believe the 50ft. was $100. I haven't bought it yet. How much difference do you think the picture will be if I use that instead of an S-Video cable?
  • Teresa
    Teresa Dec 17, 2008
    Guess I will be using S-Video..
There will be a big difference in video quality between HDMI and S-Video. If you happen to have a DVD player that uses HDMI you can upconvert your movies to 1080i if your DVD player allows it. The only problem that you might run into is your audio. HDMI has audio built into the cable and DVI does not, with the HDMI to DVI cable you are going to have to find an alternate source for your audio to travel through. If you are looking for video quality get the HDMI to DVI cable.
Posted on Dec 17, 2008
What kind of cord do I need to connect my laptop so Netflix Movies can play on our T.V.?
Hi Candice,
First, without the model of your TV *and* laptop, no one will be able to give more than general information. It is much better to provide too much info than not enough - to get questions answered quickly here. With that said..
The short answer is that you need a cable that will connect to your note book (most likely either Video [yellow], S-Video, VGA, DVI, Display Port or HDMI) and the TV (most likely RF, Video, S-Video, PC / VGA, HDMI or RGB) Only the HDMI cable will provide sound with video. The others will require either an audio connection from the laptop (probably via a 3.5mm stereo headphone output jack) to the TV (most likely standard "RCA" jacks [red & white] - or settling for the laptop speakers or external amplified speakers plugged into the headphone jack.
If you are unable to locate a cable that has the connector supported by the laptop with a connector offered on the TV, it is likely because it is not possible to connect the two (HDMI to video, etc.) with only a cable. Additional hardware (probably expensive if available) will be needed to up or down convert & split audio to make it compatible.
Take a photo of the jacks offered by your laptop and those on your TV to a respected TV / Audio store / department for additional assistance. Some Radio Shack store employees are very good - and some are just plain horrible. Save your receipts in case it doesn't work to your liking.
Keep in mind that a $50 Roku box will stream Netflix (and a whole lot more) to most TV's "right out of the box" - or by buying $10 HDMI cable online to connect an HDTV. Don't spend 20, 30 or more dollars on an HDMI cable unless you want to pay too much!
I hope this helps and good luck!
Oct 22, 2013 | Computers & Internet
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
PC to LG TV. on PC we have DVI out. We have used a DVI to HDMI cable. we have plugged this into HDMI3 input on the side of the TV. we are using a wall mount, and dont want to damage cables by plugging...
Can you assign different audio inputs on your TV to go "with" video input HDMI3
If so, you can connect the RCA cable into an input on the TV and on the other end you will need to purchase a "dual RCA female to 3.5(1/8") mini adapter" to go into your PC.
These can be found at your local radio shack type store or ebay.
I hope this helps
Magoo
Mar 08, 2011 | LG Televison & Video
I have a Sony Grand Wega KF-50XBR800 TV. There is a connection on the back of the TV that reads DVI-HDTV in that looks more like a computer connection. Is there an adapter for the HDTV from the TV to a...
yes there most certainly is a connector for this its simply known as dvi-hdmi ok they are available at radio shack or circuit city and are less than 20$ and some are a cable with both tips instead of an adapter ok :) dvi were short lived and arnt to common anymore but they still do sell them ok :)
Jan 12, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
Can't connect my emachine to 50" samsung plasmatv mod#pn50B530S2F
try going to "display properties" and adjusting the settings there. Right click on the desktop wallpaper and go to properties, then click on the settings tab. Make sure the TV setting is turned on
Mar 28, 2010 | Acer Aspire L100 PC Desktop
What HDMI to DVI-D cable will work with Philips 60PP9352 60 in. Rear Projection Television? Please help. I've looked everywhere and can't seem to find one.
Get an HDMI to DVI adaptor and use a generic HDMI cable.
Lots of DVI MALE to HDMI FEMALE adaptors out there:
Ultralink, Monoprice, Monster etc.
Jan 01, 2010 | Philips 60PP9352 60" Rear Projection...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
I want to hook up a RDC-W500C CD player/recorder to a Satellite recieverHD to a Philips 50PFP5332D/37 plamsa TV and a Panasonic DMR-EZ485VK DVD recorder Thanks much FCZimmerman bufford4@localnet.com
HI THERE,
DID YOU HAVE THE USER MANUAL FOR BOTH OF THE UNIT,
YOU WILL NEED A INSTRUCTION MANUAL FOR THAT.
KINDLY ACCEPT MY SOLUTION AND I WILL SEND THE MANUAL INTO YOUR EMAIL
Mar 25, 2009 | Sony Audio Players & Recorders
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
