Question about Refrigerators
My fridgidaire side by side Model PHS69EJSS is not running or making any sounds at all. It has completely defrosted. All lights are on. The digital read out for the freezer is flashing E and the Fresh food readout is Flashing F. I see people on your web site describing the same problem.
  • 85 Answers
E f code is a faulty frezzer fan motor . disconnect power to reset control open frz door and push in door swt and listen for f/m to run. if f/m does not run the f/m or control board could be faulty
Posted on Dec 15, 2008
Fridgidaire ffht1817lw8 noisy operation
Good Afternoon John, thank you for your post! Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become a common hum in your home. This noise also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable.
Listed below are descriptions of some of the most common sounds you may hear, and what is causing them:
A. Evaporator: The flow of refrigerant through the evaporator may create a boiling or gurgling sound.
B. Evaporator Fan: You may hear air being forced through the refrigerator by the evaporator fan.
C. Defrost Heater: During defrost cycles, water dripping onto the defrost heater may cause a hissing or sizzling sound. After defrosting, a popping sound may occur.
D. Automatic Ice Maker: If your refrigerator is equipped with an automatic ice maker, you will hear ice cubes falling into the ice bin.
E. Cold Control & Defrost Timer or Automatic Defrost Control: These parts can produce a snapping or clicking sound when turning the refrigerator on and off. The timer also produces sounds similar to an electric clock.
F. Condenser Fan: If condenser coils are located underneath your refrigerator you have a condenser fan. You may hear air being forced through the condenser by the condenser fan.
G. Compressor: Modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound.
H. Water Valve: If your refrigerator is equipped with an automatic ice maker, you will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle.
I. Drain Pan (Non-removable): You may hear water running into the drain pan during the defrost cycle. The drain pan will be located on top of the compressor for air-cooled condensers (black coils on back of refrigerator).
I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Aug 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
How do I as a tech put this fridge into defrost Model# PHS69EJSS2. Ice is forming on the back wall of the freezer and it is also cutting off air supply to the fridge side.
sounds stupid but i would just unplug unit and do a complete defrost/dry out/clean,then leave for a week on full cold.to see if any other problems exist.....also check door seals for air tightness .
Apr 12, 2010 | Frigidaire Pro PHS69EJSS Stainless Steel...
Freezer appears to be defrosting but, everything is running
Switch off the freezer and clean it properly by emptying th freeze. And then switch on the freezer
Feb 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Compressor is running, but not cooling.
there some thing is wrong check your service manual
Apr 07, 2009 | Frigidaire Gallery Series GLHS68EEQ 36" 26...
Kenmore side by side Model # 59507992
the relay overload plugs into the side of the compressor. its a common problem make sure you get one that matches your model number. it will fix the problem
Nov 20, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
