Question about Dishwashers
Dishwasher wont fill. it just runs like it is filling and the element gets blazing hot but no water comes in
    Scholar:
  • 61 Answers
Every Dishwasher has a tube that water comes through before it enters the dishwasher. This tube is connected to a pipe in your house where it was installed. (I wish this was an easy fix). You will have to pull the Dishwasher from its current area SLOWLY, so you don't pull these pipes from the wall. Note: do this when you have plenty of light or a flash light handy.
Next explore the area in the back of the dish washer and find where the connection is located. Exame the tube that is connecting your water to your house. (We had a rodent problem years ago and they chewed through the tube and all the water went into our walls and caused more damage! If the tubes look good then test for a blockage in the tubes. Feel them. Is there water inside? (some of them made clear so you can see inside them). There should be a shut off valve for the water that you can check to see if it is open or not. (More than likely this didn't randomly shut off by it self so this is doubtful that it is that simple, but you should check this out first) Turn in fully off, to the right and then back on to the left.) The same deposits that can clog a sink can clog these pipes too. There is a possibility that they are clogged and need to be repaired or replaced.
Now that you have checked all this. Try to find the area in the house where the water flows to these pipes from your main water source. Every plumber is different and the one that installed these pipes may have put a seaperate shut off valve in an area that you weren't aware about. (Someone else in your house may have found it and turned the water off at this source without understanding what they were doing. Do you have any teenagers? A curious animal with opposable thumbs?)
Short of these solutions, you need to call a plumber or the dishwasher repair shop as the only other issue it could be is the switch on the inside of the Dishwasher that allows the tube to let water flow in and out of the dish washer may have died. This might be something you can replace on your own, by googling your dishwasher model and looking up parts for it. If you like taking things apart you might be able to score the part and do it your self and save around 120 dollars or more, unless of course your dishwasher is in warranty - If so, call the number in the manual and have them replace this.
Posted on Dec 14, 2008
Do you know if it's a hot or cold feed at inlet
Hi Charles
The traditional method of supply was using hot water for filling. However, it is possible to save money on some machines by hooking up to cold water as the element in the dishwasher uses less power than your water heater. Unfortunately, some manufacturers still require using hot water for filling. You'll need to check your manual to see if this is the case. Here's a link to This Old House explaining dishwasher installation.
Hope this helps
-Steve
How to Install Dishwasher
Mar 04, 2015 | Dishwashers
My dishwasher isn't working, it fills with water then doesn't do anything. The water doesn't seem to be hot. Does it need to be heated before starting the washing action?
Try running your sink water till it's hot and then running the wash cycle. Not all washes have a quick heat element.
Dec 23, 2010 | Dishwashers
Can I use cold water fill when installing this machine
No,
There are only a few dishwashers that have good enough heating elements to be able to use cold water.... most all of them need to fill with hot water and then the element just keeps the water hot...
heatman101
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
Oct 10, 2010 | Dishwashers
My dishwasher isn`t filling with water the elements are getting hot but no water is getting through any ideas on fixing this problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 08, 2010 | Dishwashers
On model du81qdwgq1 is hot or cold connection
You are supposed to connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water.
Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has been shut off for a while. If you have questions, please let me know. I hope this helps you.
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Is the feed pipe a hot or cold feed?
Connect the dishwasher to the HOT water side. Although most dishwashers have a heating element to heat the water, they are normally installed this way to reduce the amount of time the heating element is on. This not only extends the life of the heating element, but also reduces the amount of electricity required to heat the water. Another helpful hint: Before you run the dishwasher, run the hot water tap until the water runs hot. This will fill the dishwasher with water that is already hot instead of the cold water that normally sits in the line after the hot water has not been run for a while. If you have questions, please let me know. I hope this helps you.
May 05, 2010 | Hotpoint 24 in. FDW60 Free-standing...
No water comes in my kitchenAid dishwasher
you only need prime to pump water out if you are not getting water to D/W it is most likely the water control valve
Oct 23, 2009 | Dishwashers
Water not hot nor warm
When you run the hot water at the kitchen sink until it is hot and start a cycle on your dishwasher, is water hot when you open the door after it stops filling?
If no, the diswasher is connected to the cold water line, not the hot water line. The water temerature entering should be a minimum of 120 degrees but no hotter than 140 degrees.
If the water going in is hot, but it cools down after each filling then the heating element has failed and needs to be replaced. When the heating element fails, the dishes, especially the glassware will be foggy and still dirty.
Please reply with what you find. Good Luck!
Mar 30, 2009 | Dishwashers
Diswasher wont fill
Faulty fill valve?
Timeing out with insufficient flow of water?
Hot water to hot and locking up valve?
Apr 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
