Question about Venturer 3.6" Portable DVD Player
How to connect player to tv
What wires go where to make this connection
    Genius:
  • 1,199 Answers
I need to know how your going to connect it! basic is red to red white to white and yellow to yellow,If you do not have these connections on the back of your tv you will need to buy a cheap RF modulator
Hope this helps (please rate! this is what keeps the site free)
Posted on Dec 14, 2008
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
Excellent picture but no sound
This problem has 3 possibilities, that your tv audio output is already damage or the cables that connecting to your tv and digital reciever is loosed or damage and may be your digital reciever sound pre amplifier is damage. Let's start to your tv, try to use a dvd player or cd player and connect it directly to your tv audio video input, or you can remove the connection from the digital receiver and use a small piece of wire then connect it to your tv antenna input and set your tv mode to aerial tv.If the tv produces sounds your tv is ok. To wire connection, first try to check all the cables that connecting to your tv and digital receiver specially the input, output connection,If wire is ok. Then the digital receiver has the problem try to contact service provider and ask if your digital receiver has a warranty.
Jul 16, 2011 | Samsung 50 in. TV
How do I connect my philips dvd750vr dvd player to my tv? (tv is a toshiba cx32f60). thanks
it all depends on the cord that you want to use. There are different cords that can be used to connect Tv to your player.
But I would recommend RCA cord. RCA cord is a Yellow, white and red wires. The yellow stands for video, while the white and red stands for audio left and right.
Look at the back of your TV, connect the yellow part of the cord to Video IN, the connect the red and white to Audio IN respectively.
Now, connect the other end of the wires to the player in the format; Connect the yellow to video Out, the connect the red and white to audio Out, respectively.
Turn on your TV and Player. Press source or AV on the TV remote and a display of the DVD will appear on the screewn of your TV.
That would be all.
If you still have difficulty in connecting, please let me know so that I can help further.
Yours sincerely.
Elect_Comp.
May 14, 2011 | Philips DVD750VR DVD Player/VCR
I have a philips dvd player and i want to connect it to my videocon lcd tv please help me in the wirings. any help with images will be appreciated thanking you in anticipation
the philips DVD player output gives three wire RED,WHITE,YELLOW accrording to them connect the red & white wire to the TV's red&white wires which is responsible for audio output from the dvd player,
then connect the yellow wire to the yellow inlet of the TV, which is either on the front pannel or back side of the television which is provides the video signal from the DVD.
Feb 16, 2011 | Televison & Video
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
I have my wii hooked up to the tv, but i cant hook my dvd player up because there isnt a second yellow plug.
Ur tv and DVD player have a S-Video connections ports holes for this wire right?Tries websites like Amazon.com,Ebay.com to buy this S-Video wire to used to do the connections for the tv and the DVD player together by this S-Video wire in tv S-Video and DVD player S-Video connections ports holes for this wire.Use the AV cable RED,WHITE same connections like ur Wii connections to get the Audio.
Nov 08, 2010 | Sanyo DP50747 50 in. Plasma TV
No picture
is your TV connected to a receiver or DVD player? I want to know so that I can detect if the fault is from the video cord that connects your TV to the receiver or DVD player.
Or, you can connect a DVD player to the TV and see if there will be any picture.
I hope you understand what I'm trying to say above. Your TV not having picture might be a fault from the display board/ic inside the TV or it might just be a bad wire connecting from the TV to DVD player or receiver.
So try to check the wires at the back of the TV, to be know if its a wire fault or not.
Good luck.
Jun 22, 2010 | Televison & Video
Where do the blue, red, and green wires that plug into the DVD player plug in? Are they supposed to plug into the TV set?
it is known as componant input & out put.if your tv has component input then connect three rca wires from dvd to tv and change input mode to component.if your tv doesnt have compo in then u can connect it to v in yello wire ( only one wire)
Jun 04, 2010 | Samsung DVD-V4600 DVD Player/VCR
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
Dvd setup
Most DVD players connect to the TV by AV (three wires), component (five wires), or HDMI (one wire) connections, none of which are tuned. That is, there are no channels on the inputs. Connect your DVD to the TV by whichever connection you choose. Then with your remote, select the input on your TV that corresponds to where you connected to on the back of the TV.
Dec 21, 2008 | Astar LTV-3201 32 in. LCD Television
Televison & Video Logo
49 people viewed this question
Top Venturer Televison & Video Experts
john milligan
Are you a Venturer Televison and Video Expert? Answer questions, earn points and help others
