Question about Zebra TLP 2824 Printer
My zebra LP2824 Thermal printer is driving me nutty. It skips tags between each printed one. I'm printing on thermal labels that are 1.1875x3.375 (2 side by side) so the total measurements are 2.375x3.375. I've tried several times to calibrate the printer as well, but am still having the problem. What am I missing? Oh, and I'm on Vista if that makes any difference. The printer is brand new and we already downloaded the latest version of zebra. Thanks!
  • Brian Voelntine May 11, 2010
    Have the printer's sensors been cleaned? This can sometimes cause this problem.
  • Jim H May 11, 2010
    3 questions. 1: what label design software are you using. 2: What is the firmware version. print config label to check. 3: What printer driver are you using.
    Champion:
  • Zebra Expert
  • 285 Answers
Possible is not the best printer to work on site-by site labels because the sensors that read the gab are on the midle of the label and possible can't check wen the label start and end. try the printer S4M (sensors on lenf side), or try normal labels and press the botton until flash 2 times and release the botton (calibrate).
Posted on Nov 25, 2010
My zebra lp2824 barcode printer does not print, i downloaded zebra lp 2824 from nice label still it not working, when doing print test it will print only some letters....what to do
check the driver, and the setings from the driver. Try ZDesign Driver or seggul driver from WWW.seaguscientific.com, and print the testpage, chech the connection (port) if is seria (com) check the setings speed etc...
Nov 09, 2010 | Zebra Eltron LP 2824 Thermal Printer
I want to print 2X4 labels without skipping 2 labels each time
obviously its your vb software. try using a real label program and end this issue.
Sep 05, 2017 | Zebra LP 2844 Thermal Printer
Just one of the double tags is printed on
I assume by double tags you mean 2 labels across the roll.
You need to tell your software that the roll is 2 across.
If using the software that comes with the printer, Zebra designer.
Set your label width to twice the single label and copy the barcode so that you have 2 across the label, then print
Feb 10, 2010 | Zebra Eltron TLP 2844 Thermal Label...
Problem with my Zebra LP2824 printer
You have to calibrate the printer to solve this problem
Check following to solve this problem
1)Press the feed button and hold it for 1-2 seconds switching printer on.It will calibrate the labels.
2)Install Zebra Designer driver from CD.After installing Zebra designer Add printer Zebra Designer LP2824.After installing driver right Click the printer Zebra Designer LP2824 and go to printing preferences then select advanced option and calibrate printer.It will calibrate printer
3)Check the label size is properly set in printer or not.Label width and label height in printer settings should be same as label which you are using .
Aug 22, 2009 | Zebra Eltron LP 2824 Thermal Printer
Printing a 2.25 in label on Zebra LP2824. Prints
Recalibrate the printer and you should be good to go. Do this by turning the printer off, press and hold the button and turn on the power. When the light flases red let go and it will calibrate, at the end it will do a printout. Reboot the printer and your fixed.
Jul 28, 2009 | Zebra Eltron LP 2824 Thermal Printer
Slow printing to LP2824
This appears to be normal operation.
Aug 14, 2007 | Zebra Eltron LP 2824 Thermal Printer
LP2824 feeds a label but wont print on it?
can you give more info? it sounds like you driver is set to thermal transfer mode but you have a direct thermal printer (LP not TLP)
Apr 24, 2007 | Zebra Eltron LP 2824 Thermal Printer
Zebra TLP 2824 Printer Logo
498 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
