Question about Fisher and Paykel IWL12 Top Load Washer
Lights on no one home!
I have a Fisher and Paykel smart drive. It turns on - all the display lights up and can be changed, but when you close the lid and press start nothing happens. I have removed the lid to try and find a switch to see if thats the problem but I cant even find a switch. We have 4 kids so I just spent a fortune down the laundromat!! Your help would be really appreciate.
  • ray539 Feb 18, 2008
    REPLACED THE COLD AND HOT SOLENOIDS NO JOY WOULD HAVING NO WATER BEING PUMPED INTO SMALL RESEVIOR PREVENT CYCLE FROM STARTING I HAVE AS YET NOT TOUCHED WATER PUMP CHEERS
  • 28 Answers
Some model smartdrives have a hidden switch activated by a magnet moulded in lid if it has gone to open circuit it thinks the lid is open.This open circuit when lid opens is a safety feature should someone open lid during lid cycle,some become stuck due to corroision and need to be changed
Posted on Jun 22, 2008
    Novelist:
  • 114 Answers
YOU HAVE THE RIGHT IDEA ... ALL WASHERS DO HAVE A SAFTEY SWITCH TO PREVENT PEOPLE GETTING HURT WHEN WASHER IS IN AGITATE OR SPIN CYCLE. IF YOU CANT SEE A SMALL HOLE INSIDE THE RIM OF THE TOP UNDER THE DOOR WHERE A PEG PUSHES DOWN TO CLOSE THE SWITCH ... THEN THEY ARE USUALLY BUILT INTO THE HINGE ASSEMBLY. THE START BUTTON ALSO ACTIVATES A RELAY THAT MAY BE BAD.
Posted on Apr 29, 2007
There is a switch at top l/h corner. as you look at the machine it should be on your far righn on the hinge line
Gw612 error code lights
the motor controller needs replacing. this fault is not servicable at home.
Sep 07, 2013 | Fisher and Paykel Fisher & Paykel Washer
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
FISHER & Paykel 6.5 Smart Drive - No display lights
You need to get hold of a multi-meterand check the resistance of the pump, It should be 33ohms or close to it, the pump is part of the power circuit and the machine will appear dead if it has blown or is unplugged, If the machine was running without the earth wire to the pump connected and the pump had a fault/blockage there is a very good chance that it has blown the motor controller module. It requires the earth to provide a fault path to earth.
Mar 03, 2012 | Fisher Paykel Eco IWL16
I have a fisher and paykel smart drive 5.5 that will not sart filling withwater. All the lights are on and the hoses and filters are not clogged
Hi just found your posting.Do you still require help?Sounds like a lid switch fault to me.Does the machine beep when you push the start button.Please reply for further help.Looking forward to your reply.
Oct 09, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Feb 06, 2010 | Fisher Washing Machines
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fischer Paykell 7.5kg Smart Drive top load washer
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Jul 24, 2008 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel smart drive - all the lights come on!
It has put itself into the display mode (used in shop displays) Try turning power off and unplug from the wall outlet for a couple of minutes. Plug back in and see if it has come back to normal. If not then either the display board or the main board will need to be replaced. Get a service tech out to check which one is faulty.
May 13, 2017 | Fisher and Paykel (IWL12)
Fisher and paykel smart drive... Water does not go in
check the reed switch under the lid (magnet) and the cold water may be just a cold valve they get slow flow common problem
Nov 06, 2007 | Fisher Paykel EcoSmart GWL15
Washing machine has packed a sad
The problem is definitely in the lid switch. Your machine has a reed switch which is located under the hob on the right side of the tub. There is a magnet built into the lid which activates the reed switch when the lid is closed. You will need to replace the reed switch and harness.
Oct 06, 2007 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
213 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
