Question about Hitachi 61UWX10B 61" Rear Projection Television
Hitachi 61udx10b picture problem
I have a hitachi 61udx10b. going from the left side to the middle of tv a yellow blob. under the yellow blob a blue area with shadows. The bottom half of screen is clear and the picture is good.
  • Hitachi Master
  • 5,138 Answers
Replace both of your STKs these are your convergence ICs STK392-110- use STK392-180s .
Posted on Dec 14, 2008
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaHitachi 61udx10b picture problem - 2c07611.pngs a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
Testimonial: "works well with new convergence kit installed"
Have changed the bulb because of yellow blob on the picture and it has made no difference
the yellow blob is from a fried polarizer on the blue lcd panel due to excessive dust and heat. you'll have to replace it, but hitachi doesn't sell individual optical engine parts, so you may have to replace the whole optical engine.
Jan 18, 2010 | Hitachi CP-X440 LCD Projector
Hitachi 55vs69a yellow blob in center
you most likely have a bad light engine.
Aug 20, 2009 | Televison & Video
Blue blob on projection tv screen
CALL HITACHI THEY MIGHT HELP WITH REPAIR, HAS A BAD OPTIC BLOCK.
Apr 18, 2009 | Hitachi Televison & Video
I have a hitachi 50 in rear projection tv and i am getting a yellow circle through out the middle of the screen what do you think that is and how do i fix it?
I looked back and see your talking about a crt type. My bad. A small yellow spot is most likely dirt or a bug in the blue optics. Tale the front off the set and with the tv on look down into the lenses. If you see a blob of dirt or a bug this is your trouble. Be careful not to move the blue tube but take the lens assembly off and clean the surfaces. There are four screw that hold just the lens assembly. The other screws shouldn't be touched. It will need alignment otherwise.
Mar 28, 2009 | Hitachi 50UX57B 50" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Hitachi 50v500
To all that are experiencing the blue blob. This is result of poor maintenance. Projectors must be kept clean on all air intakes. This is to help you all understand the failure cause. Usally not worth repairing.
Aug 21, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 61UWX10B 61" Rear Projection Television Logo
444 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
