HDMI DOES NOT WORK ON MY DYNEX 37" HDTV FLATSCREEN
MY DYNEX 37" HDTV HAS A OUTLET FOR HDMI. I PURCHASED THE CORRECT HDMI CABLE AND IT WORKED BEAUTIFULLY FOR THE FIRST DAY. HOWEVER, THE NEXT DAY I WENT TO WATCH TV AND MY TV COULD NOT FIND A SIGNAL. I EXCHANGED CABLE BOXES AND EVEN PAID FOR THE CABLE COMPANY TO COME OUT AND TRY TO REPAIR PROBLEM TO NO AVAIL. I HAVE TRIED A NEW HDMI CABLE AND IT STILL WILL NOT WORK. THE ONLY WAY TO GET A HD PICTURE IS TO USE THE COMPONENT OUTLETS. THE PICTURE IS GOOD BUT NOT AS GOOD AS WITH THE HDMI OPTION. I AM HOPING YOU CAN SOLVE THIS PROBLEM. THANK YOU, PACKY PAULES
E-MAIL ADDRESS (in lower caes)
SOURCE: No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
SOURCE: No sound on NON HD channels
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Posted on Jan 06, 2009
  • 5 Answers
SOURCE: sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Posted on Feb 10, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
  • 10 Answers
SOURCE: Vizio L32 32 in. HDTV LCD HDMI input not working
I recently had the same problem with my vizeo hdmi port # 1 going bad. Tried everything to fix and called vizeo. There solution for a master reset was turn off tv and unplug from the wall. then hold down the power button for 30 secs and let go. plug the tv back in and hold down the volume down and input select buttons down on side of the tv for 15 secs. release the buttons and turn the tv on after powering down all the components connectd to the tv. If this does not work they told me you need to have it sericed for a bad hdmi input. Hope this info helps anyone out there. It didn't work for me. Its a bummer cause the tv is well taken care of and only 18 months old. Best of luck to all others.
Posted on Oct 10, 2009
Tried to plug in my mac to a dynex flatscreen using VGA gagaware chord. screen is black and says "not supported". is there a way to make this work?
The answer is NO with a possible yes... NOT with the VGA connection, not going to happen EVER. On the other hand, if the TV has an HDMI port, then I suggest you connect your MAC using an HDMI cord suited for that purpose. You should be able to get satisfactory results.
Mar 19, 2013 | Computers & Internet
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
How do i hook it up to computer?
If your computer had HDMI or DVI, that is the connection you will want to use. You can get an HDMI or HDMI to DVI cable depending on the connection your comptuer has. If it doesn't have either of these, VGA would be the next best solution.
Jun 29, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Just bought an open box 32L152A-11. plugged in the electrical cord and inserted the input cable and screwed it in securely. fios box is not an "hd" so i am not i nserting a hdmi cable. i...
from what i gather you are trying to get hdtv to work with rca cables without using an hdmi cable . if this is correct then all you need is RGB cables . just like rca but they red green and blue . look on the back side of your tv , there should be a set of RGB inputs and also rca .
Feb 09, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I purchased the Lt37Hvs on Aug31,2006. The DVD player and the TV have always been connected by an HDMI cable. Last night the HDMI stopped working. I pulled the connectors on each end to clean and...
Check to see if the DVD has a setting to change it's Output... ie: Can you select, HDMI, RCA, Component? via the DVD? If so then reselect the correct one, perhaps Component is the "Default" output?
Jan 30, 2010 | Olevia LT37HVS 37 in. LCD HDTV
Purchased and set up both Vizio SV370XVT HDTV and
Try setting your cable box for Closed Captioning. Worked for me.
Jan 21, 2010 | Vizio VX37L Television
Using a vga cable to hook up my pc to the tv and doesnt work
did you change the imput --use the remote--push imput, change to component
Mar 12, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Televison & Video Logo
580 people viewed this question
Top Televison & Video Experts
Electro Med Services...
