Question about Sharp AR-C270 Color Copier
L4-05 error code
The L4-05 error code is an indication of a problem in the color developer drive system. This problem was only infrequent at first but is now constant. So far I have tested the motor in the appropriate sim 25-1 test. The motor runs seemingly ok. I have installed a new DV motor for the color developers with no success. All fuses are good.The load appears to be all right. I am down to one connector board, one PCU main board, and two ribbon cables. I am trying to find a way to eliminate the components without going to the expense of buying the parts. I did change the developer mix and went through the setup but the machine ran ok right after that. I sure would appreciate some help. Thanks, Gerry
  • 3 Answers
If you set up dev with 25-02,and L4-05 came up then the most likely cause is a worn out developer drive gear ( CGERH1291FC01 )
Posted on Jul 27, 2007
HOW TO RESET CODE C7911 FOR KYOCERA 2550CI
That code indicates a problem with the (K) developing unit, which is the black color developing unit. Try removing and reinserting the black developing unit. If that doesn't work, probably need to replace the developing unit. Hope that helps.
Sep 28, 2016 | Kyocera Office Equipment & Supplies
Canon e000020-01a0 is it alright to clear the error and work the machine
Yes, The error is a standard code for the drum/developer of a particular color. The 01 is for yellow, the A0 is indicating the measured value of the developer concentration is considerably low. This may be a reult of the drum unit going bad or serveral sensors going bad. How many copies does the yellow drum have on it? Warranty is for approximately 40,000 prints.
Aug 18, 2012 | Canon imageRUNNER C3200 Copier
Hi, i have problem with my hp color laserjet 5550 printer.it saiys printer error 59.c0
59.XY A printer motor error has occurred.
(X=C=developing disengaging motor rotation error)
(Y=0=no color/black)
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 29, 2011 | Office Equipment & Supplies
We have a Canon Image Runner C2880 with an error code of E00025-002 What does this mean and how do I fix it?
This is error in the toner motor. The 0002 is indicating that there is error in the Cyan developing assembly toner supply. You could try switching one toner motor for the other and see if the error cahnges to the other color. The book indicates that it may be the DC controller as a last resort. Check the connection between the motor and the DC controller. Hope this helps.
0000 is yellow, 0001 is magenta, 0003 is for black.
Apr 13, 2011 | Canon imageRUNNER iR C2880 Color Copier
Errore canon e000020-01a0
This is toner related error. The code after the dash indicates what color is causing the problem. The fist 2 digits indicate the color of drum. 01 is Black, 02 is Magenta, 03 is Cyan, and 04 - Yellow. The "A0" is indicating that the measured value of the developer concentration is considerably low. The ATR sensor is faulty. The SALT sensor is faulty. The Intermideate Transfer Belt is soiled. I believe depending on how many copies the black drum has, it may be bad. They are warrantied for 40,000 copies. This should get you in the right direction. Good Luck.
Feb 26, 2011 | Canon imageRUNNER C3200 Copier
On power up displays SC441
SC441 indicates Development Motor Lock / Drum Peripheral Component Motor Lock.the code indicated one of four things. It could be either the Color PCU, the gears that drive the PCU, the motor or control board. The easiest of course is to replace the color PCU, but that runs around $300, but the other parts required a bit of disassembly to examine.
Oct 21, 2009 | Ricoh CL3500N Laser Printer
Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
May 27, 2009 | Toshiba Office Equipment & Supplies
Sharp arc 270 error code l4-04
Possible bind in one or more of the developer units. Replace as needed. Sec. 11 Page 11-61 it talks about Paper Feed Drive Motor, it is the same motor as the Black Developer Drive Motor.
For L4-04 swap those two motors around to troubleshoot bad motor
Feb 03, 2009 | Sharp AR-C270 Color Copier
Sharp AR-C270 Color Copier Logo
280 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
