This is for Ginko: Last Tuesday I described a problem with my Gateway 3520 going to "black screen" 5 secs after turn on. You analyzed a cooling fan problem. I removed the cover etc. and found that the fan did not run so I purchased a complete heat exchanged assembly. I have installed the assembly and the fan still does not run. First "power-up" lasted approx. 20 secs before "black-screen" now has returned to 5 secs.
  • tony308 Dec 17, 2008
    The Jaddude reply was not at all helpful. Example: how, what and where are the connectors etc. that I should check, this is a laptop and things are extrememly difficult to access unless they happen to be visible through one of the panels.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
See if the connectors are broken or working
the wires/board integrations are intact or not
see if it works
if not post any other data adn i will solve it
Posted on Dec 14, 2008
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Dec 14, 2014 | Minolta Office Equipment & Supplies
Runs very hot at times cannot leave hand on lay below keyboard area, fan is not on. When it does this I start cooling mamually by pushing fan around with paper clip thru air intake grid until it starts...
Hi rdn52...
Sounds like your cooling fan is faulty...
The computer should not get very hot like you describe...the fan should keep it cool...
Replace your cooling fan...
Please take time to rate me
Sep 24, 2011 | Gateway E-475M Notebook
My Gateway ZX4300 screen is not working. The screen does not turn on at all but the fan is working and the hard drive is as well.
gateway zx4300 black screen fix
i think i might have found a fix, if you know how to fix the xbox with the fan trick this one will sound close to the same.
if when you turn the computer an you get nothing not one bit of color or brightness from the screen this is your fix, well it worked for me.
i am not responsible for any more damage you might encounter, this does require disassembly
1. take the computer apart until you have the fan and heat sink in front of you.
2. remove fan and heat sink from mother board.
3. (at own risk) with computer open an heat sink off plug in the power cord and turn the computer on.
4. leave computer on for 8 to 10 mins.
5. turn computer off after 10 mins remove power cord and re install heat sink and fan.
6. hold pwr button down for 15 sec.
7. plug computer back in and you should now have your screen back.
this method worked for me i am using the computer with the bad screen to type this up an has been restarted a couple times an is still working fine! hope this works for you!!
Aug 11, 2011 | Gateway One ZX4300-41 (PWGAW02017) 20 in....
Blue screen shut down now black screen fan running thats about it gateway m6332
Assuming you have already tried the power adaptor and that is ok and the charging port is not loose, I think the problem may lie in overheating. The CPU will stand up to 90 degrees c but the graphics chip, which is cooled by the main fan as a secondary consideration will not.
You should remove the inspection hatch (I think on the gateway models there is a larger hatch under the laptop) and see if there is any build up of dust or debris around the cooling fan. heatsink and radiator / vents. If there is, remove it with a paint brush or hoover.
If this does not resolve the problem/ or the fan is clean, remove each ram module in turn and try booting.
If there is still no signal, try it on an external monitor, if you get a picture, the issue is with a failed screen / inverter or VGA cable. If you do not get an image, I'd stick with my original thoughts that the graphics chip has been damaged
Jan 18, 2011 | Gateway Computers & Internet
I have a Linksys Wireless G WRT54G Router version 5 and I lost my setup disk and cannot access the internal web based setup and Iv done everything Iv read to do and now its not even showing up as a...
Hi there. No need to run the setup CD. Check the IP address first to see if the computer is communicating with the router. Go to command prompt (if XP, simply click start then go to run and type in CMD and hit ok. A black screen will pop up. Type in IPCONFIG then enter. Check the IP address and default gateway (by default, the router's IP is 192.168.1.1 which will show as the default gateway). Launch internet explorer and type in the default gateway on the address bar. (No www). If you cant pull out the page. Go back to the black screen (START>RUN>CMD) and type in ping (default gateway) ex. ping 192.168.1.1 there is a space between ping and the default gateway. If you got 4 replies you should be able to access the router's page if not, reset the router by pressing and holding the reset button of the router (usually it is the red hole at the back of the router along with the ethernet ports) for 30 seconds. After 30 sec, power off the router (unplug at the back)never release the reset button and wait another 30 sec then plug the power back in and wait another 30 sec before releasing the reset button. You should be able to access the page then. Go back to the black screen (START>RUN>CMD) then do again a ping test. type in again ping and then the default gateway. (ex. ping 192.168.1.1). You should be able to access the setup page now.
Sep 08, 2009 | Linksys Wireless-G WRT54G Router
Gateway profile all in one system shuts itself off
I just had a machine in the other day with the exact problem you describe. Don't know if this will help but they had a worm and when the anti-virus kicked in or they opened any type of online program like a broswer or email the computer would shut down.
Also hardware could be the issue. If its not the above issue could you tell us when the last time the heatsink was cleaned. What if anything your doing when it shuts down....
Mar 23, 2009 | Gateway Profile 4 All In One (MPN...
How do I know if my Directv HR22-100 HD receiver is dead?
one last thing you can do, if it doesnt work the dvr is dead. reset the dvr and wait for the hello screen and then the screen will go black. when it turns black, hold the down arrow (on the front of the dvr) and the record button for at least 5 secs. this will re-format the hard drive. if it doesnt work the dvr is dead
Jan 02, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Monitor goes black suddenly
nvdia 6600 requires a minimum of 450 Watts of power to ensure that everything works properly. So if you want to continue using your nvdia card, an upgrade will be necessary.
If you want to test to see if it is the nvidia card, you need to remove the card physically from the system, then boot with the onboard video. This action will eliminate any conflicts between the two video cards. Before doing this you may need to go into device manager and make sure the onboard video card is not disabled.
Jul 26, 2008 | Gateway 838GM (RB838GM) PC Desktop
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
