Question about Refrigerators
Bottom fridge section isn't  staying cold ?model number is WRN33NWB6 please help? kind regards jo model#et1fhtxm001 bottom of ref.not getting cold,the freeze get a little not melting ice jet.please help d.murphy
  • 734 Answers
May be there is a problem in the rubber seal(Magnetic seal) of your fridge.
Thanks
Posted on Dec 14, 2008
    Sergeant:
    Champion:
  • 304 Answers
how old is the unit.
sometimes fridge need freon if it was not gettin cold.
  • Elizabeth Krijt
    Elizabeth Krijt Dec 14, 2008
    yes. like just the one said check also the relays part
    Genius:
  • 2,920 Answers
You might want to check the relays on the back to make sure they are ok
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Only half of the freezer and half of the fridge are working
heat rises and cold stays down on the lower shelves,if the evap fan motor isn't blowing this will happen,next time send the brand name and model number off of the machine,open the freezer door,if you don't hear the fan blowing you have a bad evap fan motor,all it does is the freezer gets cold,the fan blows the cold air from the freezer to the fridge section,also if the fan isn't working when you remove the back inside wall of the freezer if there's any ice melt it out with a hair dryer,unplug the machine before you start working on it,call your parts store,give them the model number and they will sell you the parts you need.
Oct 10, 2011 | Refrigerators
My Kelvinator opal N620F freezes everything on the bottom half of the fridge, yet the top isnt cold enoough. If you feel the top of the fridge on the inside it has no chill at all. Also the water section...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 26, 2011 | Refrigerators
Hello, My Hotpoint FFA60 fridge freezer is freezing my food within the refrigerator compartment. I've cleaned out the drainage pipe. do you have any suggestions please? thanks for your help Kind...
Leo Ponder
imufo2
Sep 12, 2011 | Refrigerators
Samsung fridge model= rf4287ha. sat temp. -19 and 1 on freezer and fridge respectively. fridge temp. stay 15 and up .not coming down even after hours. things not cool as should be. why.
Leo Ponder
imufo2
Sep 10, 2011 | Samsung RF4287HA
My fridge unit isn't cold enough even iv put it on no 5 airflow u can hear the motor but isn't getting cold enough my bottom freezer similar top self only just frozen bottom self food is fine is it...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
If
you need more help go here:
MORE
TIPS AND TRICKS:
Leo Ponder
imufo2
Sep 05, 2011 | Bosch Classixx KGV28323 Bottom Freezer...
Hello, My fridge side of my hotpoint model # Hsm25gftc sided by side fridge/freezer isn't getting cold anymore. I purchased it in 2007 I believe. I've tore the ice maker and tray out and pulled...
if the freezer is working fine it sounds like you could have a bad damper control,also there's another thing i want you to check first,hotpoint is a g.e. product,they have sensors in the machines,you said you had the back wall off,take it off again and on top of the evap coil you'll see a sensor,it looks like a white bullet with two whits wires going to it,look at it and if where the wires connect to it it has a black ring around it you have to change it out,also ther's one of these sensors in the fidge section too,it senses how cold the fridge is and tells the damper door to open and close,it sounds like your damper is staying shut,the part number for the temp. sensors are WR55X10025 and it's like 8 dollars,if they have the black ring on them they most likely are your problem,the new sensors are all white,if you have the white sensors then you could have a bad damper.go to this site,it's sears site http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSM25GFTCSA/1811/0165000/H0712760/00006?blt=06&prst=&shdMod= go to the fresh food diagram and look at the damper and the sensor,one of these parts are badmalso g.e. has had alot of problems with the mother boards,the computer board in the back of the fridge,if the condenser fan and evap fans are running fine and the freezer is fine then i would replace the damper and the sensor but change out the sensor first because it's 8 bucks,if that doesn't do it then buy the damper,all it does is the fan blows cold air from the freezer to the fridge section,if the damper isn't opening the air can't enter into the fridge section.hope this helps and points you in the right derection,let me know how you make out,good luck salde
Aug 12, 2011 | Hotpoint HSM25GFRSA
Fridge is warm, was collecting water inside. Freezer is working fine. Increased temp but not responding. It is a bottom freezer model
send the model number off of the fridge,if the freezer is working fine then no air is being blown up to the fridge section,all it does is blow cold air from the freezer to the fridge section so either the door was left open and this is very common with a bottom mount freezer or the evap fan isn't blowing or on some models there's a damper inside the fridge section,the damper door opens and closes to let cold air in,when it reaches temp. the door closes,sometimes the door gets stuck in the closed position or the open position and the fridge freezes or gets warm depending on where the door is.first thing open the freezer door,do you hear the fan blowing,if not you could have a bad evap. fan motor,next look at the ceiling and on the packages,do you see frozen water droplets,if so the door was left open and the air ducts are froze up from the warm air getting in from the door being open and mixing with the cold air freezes up the air ducts,also stick your hand onto the back inside wall of the freezer,if there's like snow or frost on the inside back wall of the freezer you could have a defrost problem,bad defrost thermostat,heater,timer or board depending on the model or last a bad damper,when you open the fridge door there are air ducts usually up top and in the middle you should feel cold air blowing in,this is your problem the air isn't making it into the fridge section.if the door was left open,unplug the fridge,remove the food from the freezer and with a hair dryer heat up the back inside wall of the freezer and blow the hot air into the air vent holes in the back wall to melt out the air ducts,keep heating it up until you don't see any more water dripping,you can see the water dripping through the vent holes.so let me know what you find,send the model number and we can go from there.look up near the ceiling in the fridge section on the right hand wall and you should see a tag with the model and serial numbers,send the full model number so i can see what you have in your machine.
Jun 12, 2011 | Maytag Refrigerators
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
