Question about IBM ThinkPad T30 2366 Notebook
T23 Thinkpad could not power up
Hi, I have Thinkpad T23 crashed due to battery running out. After plug the powercable and newer battery in, it does not get powerd up. It's not hibernating. I see the green battery light only and do not see responding from pressing power button. I hope it's a small issue I can troubleshoot myself. It contains important files to recover. Please help me Thank you.
  • Kevin Chung Mar 15, 2007
    Hi, Tim,
    I apperciate your comments and helps.
    However, it seems not the powersupply issue. I replaced the battery with known good and tried to power up but it did not help. I see the battery light green on the PC but when I press the power button, nothing(no blinking, no fan running....) happens. I am suspicious any internal part that may cause the problem.
    Per recovering files, you mentioned 40pin adapter with external drive case. Can I buy it from the store? and attach to the PC w/o opening? I appreciate your help again.
    Kevin
    Novelist:
    Champion:
  • 202 Answers
Your machine should run without the battery, just plug it into the power supply. You may check the powersupply itself. Maybe the power supply was bad and not the original battery. You can pickup one at a computer store. A universal costs around $100.00 to $120.00. The power supply is the (usually) the rectangle box that is part of the power cord. Let me know if that was it. Good Luck. Tim
Posted on Mar 15, 2007
  • Timothy Higgins
    Timothy Higgins Mar 15, 2007
    if worse came to worse..You should be able to recover your files using an external drive case w/ 40 pin adapter to read the IBM hard drive as a slave and recover files.
    Still Tim
  • Timothy Higgins
    Yes you can get a hard drive enclosure. You'll need to get a 2 1/2 drive adapter(aka 40 pin). Frys, CompUSA , The internet. You would hook the drive via USB and view the drive as a slave drive.
I have my thinkpad t23 laptop, when plugged power core with battery power pack and pressed on power button and amber light start flashing yellow and laptop cannot switch on. when i removed battery pack,...
Hi there, It seams charger or battery is faulty. It is hard to say which of the 2 is faulty as alot of laptops will not run if the battery is not installed. I would advise you take it in for repairs so they can test your battery and charger.
Regards,
Jul 22, 2011 | IBM ThinkPad T30 2366 Notebook
T23 laptop. Put in new battery. WIth battery in
poor battery contacts or dead battery cell doing this flickering
replace the battery if contacts are clean inside the computer
Jul 06, 2010 | IBM ThinkPad T23 2647 Notebook
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
Spilled water on thinkpad t23 kybd
Hi, let it dry for a good few days, then try , hopefully it will; be ok.
Anthony
Jan 30, 2010 | IBM ThinkPad T23 2647 Notebook
2002 IBM ThinkPad T23 battery problems/won't run without power
It doesn't look to me that you're doing anything wrong there.
Was there a specific installation requirement for the battery?
I recently changed my battery on my IBM/Lenovo and all that was necessary, was to let it charge fully before usage.
If you say your battery was charged for "a few days", then I assume there is something wrong with the battery. Next to your taskbar you should see a battery symbol. Double-click on it and you should see the Thinkpad Power Manager. If there is a tab called "Battery Information", see if that gives you more details. Look at the Manufacturing date!
If you really can't run the laptop without being connected to a power source, I would definitely return the battery or at least call the vendor. If your computer is running fine otherwise, there should be nothing wrong with the machine itself.
If you can take a screenshot of that battery information window adn post it here, I am happy to look at it.
PS:
You're doing the right things when you try to use the laptop without an external power source - that's the whole idea, isn't it?
Jan 09, 2009 | IBM ThinkPad T23 2647 Notebook
WILL NOT CHARGE BATTERY
Do you get steady or blinking CHARGE indicator light on the laptop somewhere? If not, the WALL-Wart/External power supply or its connection is bad. This can be due to stressed wiring, bent DC socket or cold-solder joint where it mounts to the motherboard (inside case)... or bad outlet (house socket) or a blown PS
Dec 24, 2008 | IBM ThinkPad T23 2647 Notebook
BATTERY (Li Ion) NOT RECHARGING
in the case of my T23 laptop. when i plug in the ac adapter the battery will charge but when i turn on the power button. It won't boot and will shut off eventually. cant you help me with this
Nov 08, 2008 | IBM ThinkPad T23 2647 Notebook
T23 wont boot
I would unplug it and remove the battery. Plug it back in and try without battery, if it still doesn't work, unplug the power again and remove the memory (RAM). Plug it back in and try again without RAM, if it beeps then the motherboard is probably good. If you had more than one piece of RAM, try one at a time and see if you get it to boot with one of them.
Jan 11, 2008 | IBM ThinkPad T23 2647 Notebook
No LCD Display, Does not Boot
I would check the power adapter with a multimeter first thing.
Nov 12, 2007 | IBM ThinkPad T23 2647 Notebook
Power problem
then the battery is not holding charge try leaving power cable in and switch on
Aug 22, 2007 | IBM ThinkPad T23 Notebook
IBM ThinkPad T30 2366 Notebook Logo
99 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
