Back to:
Tags:
Nor-Lake Freezer Norlake Refrigeration 6' x 6' Kold Locker Walk-In Freezer - 6' 7'' High w/Floor
Does my freezer require any routine maintenance?
By Cato - usenet poster
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Helpful (85)
Brad
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There's little actual "maintenance" required. However, if your freezer isn't self-defrosting, you have to defrost it regularly. And if it's self-defrosting, you need to clean the condenser coils occasionally. See the Maintenance Tips section of our website for more information.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Does my freezer require any routine maintenance?:
I don't want to Accept this solution
Can you Help with these Freezers problems?
Freezers
hi My mum has lost the manual for her Philips fridge...
Freezers
alarm will not shut off even after quick freeze or alarm...
Freezers
Ice maker leaks inside freezer like the tray is...
Nor-Lake Freezer Norlake Refrigeration 6' x...
my freezer is not cooling properly , my suction pressure...
Can I turn fan off while oven is still hot?...
Loading problems.
Repair Service
Find Freezer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
