Question about Smeg Ovens
Oven not working - fuse blown
Our oven is not working and every time we chnage the fuse it blows.....
  • 71 Answers
You have a short. Is anything turned on the oven , if not you have a loose wire coming to the switches or they are bad
Posted on Dec 14, 2008
  • Smeg Master
  • 3,463 Answers
Probably the oven element has gone .Disconnect element and try again if fuse does not blow, change element.
Plz rate this solution.
Thanks
Where is the fuse in wall oven siemans
As most building codes require Ranges/Ovens to be on an independent circuit, most do not have fuses installed. Chances are the element in the oven has blown out, leaving an open circuit, much like a fuse would. This would explain why everything else works, but that does not.
Aug 31, 2016 | Ovens
Miele 212 oven does not work. We have a Miele oven that does not work anymore. 220V gets to the oven and then nothing happens, no lights, no display, nothing... Advise anyone?
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
May 18, 2015 | Miele Ovens
Troubleshooting power issues for whirlpool accubake double oven
5.Even a bad relay door switch will hinder your oven from operating.
Mar 02, 2015 | Whirlpool Ovens
Problem start when i turn Oven only on teka, then the fuses blown up. I can still use grill but whwn I turn to oven fuses go blow up again.
Hi! It seems it is not the heating element! It seems to be before that. Either a short circuit delivering to much current thus causing the blow. I would check the corresponding cable all the way to the circuit and the circuit elements corresponding to the oven element. The grill and oven elements being "independent" explains why grill still works. (A short circuit seems quite possible to me!)
Dec 06, 2014 | Ovens
No power after self cleaning
5.
Dec 14, 2013 | LG LWD3081ST Electric Double Oven
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
5.
Dec 27, 2012 | Belling Ovens
My bosch double fan oven has cut out and has blown the fuse
there is a little control board that might be defective on .
Feb 24, 2010 | Ovens
The oven would not start
It doesn't work at all If your microwave oven doesn't seem to work at all, check these: 1)Fuses---- Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it. 2)Door switch--- If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. please do not forget to rate the solution.thanks.
Jun 12, 2009 | Ovens
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Beaumatic B151SS Single Oven Problem
Disconnect the element, and run the oven for at least 30 mins,,if it does not blow fuse, then more than likely it is a faulty element.
What I cannot understand is that you say the thermostat light is on after the fues has blown? I would have thought that the light would be not be on, if the fuse has blown.
If after replacing fuse and the stat is in the off position, and the indicator light is on then indeed the stat is faulty.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Baumatic B151 Electric Single Oven
Ovens Logo
325 people viewed this question
Top Smeg Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
