Question about Lands Phones
Problem with AVAYA ACS R 7.
Hi, we have A C S AVAYA relese 7. any time there is power outage
system loses all progamming. we put new battery on system.also we
did programming#123 and # 124 aqnd #125. and top of all these
we install power surge.seems nothing helps. we but a new A C S R. 7.
but problem insiste. we also install new power outlet. nothing helps.
can you help us? thanks.
    Scholar:
  • 61 Answers
Parviz3,
This unit sounds like it is like a computer that loads the program everytime it is turned on. When I am working on HD Video and I don't want to loose all the work I have been currently working on due to power outages, I put a UPS Battery Back up system on it that is capable of keeping my computer on for at least 30 minutes while things are being worked out.
This would be my suggestion for you. Buy an independant Battery back up power supply unit from a local store and be sure to get a medium sized one. I assume this phone system uses very little amperage and with such a battery back up system would stay on for days when your power is out. That would be the easiest solution and less time consuming for anyone at this point.
Posted on Dec 14, 2008
How to restore voicemail after power outage avaya
The only way to restore the setting is through a Backup & Restore card plugged into the system. Also check the system batteries. This will keep power to system during an outage.
May 21, 2014 | Avaya Eurostyle 18D Corded Phone
I need to replace the batteries and i dont know how or where to do this
Somewhere, like in the electrical room, is a place where all the wires for your phone sysem go. In that room, or closet, or whatever is a Partner ACS phone system. The cards are either light gray or ivory colored and it has a bunch of modular jacks in the face of it. One of the cards is the ACS processor and it has a battery compartment on the lower right side of the face of the unit. Without turning off the system, you can slide the lock over, pull the battery holder out, and put 2 new batteries in the holder. That will stop the "change battery" message.
Carl
Feb 21, 2011 | Avaya Corded Phone avaparp18d
Partner acs 5.0 keeps losing programming when power goes down. I've replaced the batteries numerous times. Any suggestions?
Your ACS has a known software bug. You need to contact the place you purchased it from. They will need to open a ticket with Avaya TierIII, and they will have to upgrade the firmware of the control unit.
May 21, 2010 | Avaya Partner ACS 308EC (108463001)...
Programming auto attendant on partner II
The extensions in the voicemail group are not programmed. You need to put the ports that the system sees the voicemail, into #505, group 7.
Apr 10, 2010 | Avaya Corded Phone avaparp18d
I have a message that says replacesysbat w/power on what do I do
Well, then you have a Partner ACS. Go to the phone system, in the center of the 5 slot carrier, is the processor. You will see on the bottom, there is a grey cover, with a black poece that slides up. Slide black piece up and pull out the battery holder. Replace the batteries and reinstall. Make sure you do all this while power is on, as the programming will be lost if it loses power, those batteries keep programming if the power is lost.
Dec 17, 2009 | Avaya 5610 IP Phone
I bought a used avaya partner phone system online. It came with Partner mail vs module... I cannot access the menu for voice mail to set it up... Avaya directions say pressing (intercom) 777 but all I get...
Did you really think it was going to be that easy?
You have to program the VS in the proper hunt group (7) to make it work. For example, if you put it in the 2nd slot, because it was only a 2-slot carrier, it would become extensions 22 and 23 on a 2-port license and 20-23 on a 4-port. The Partner Mail is installed to the right of any 206 or 400 cards, so that you don't have any holes in the extension numbering plan.
Here's a manual for the VS R4. It should work for your system for the basic installation. http://public.carl.airpost.net/Avaya/Partner%20Mail%20VS%20R4%20Installation%20and%20Programming.pdf
Page 35 is your installation information and page 50 tells you how to program the ACS.
Good luck.
Carl
Nov 05, 2009 | Comdial Avaya Partner ACS with Voice Mail...
I can't set up the intercom system on my Avaya Partner ACS R7
To program a page button for other extensions.
At the phone, press Feature 00
press the LIGHTED button you want to program.
press the LEFT intercom button, followed by * (star) and the 2 digit extension number.
Repeat for more buttons.
Feature 00 when done.
Now you can just press the button, and it dials intercom *10 (example)
it will activate the speakerphone and you can talk.
Jul 09, 2009 | Avaya Corded Phone avaparp18d
Lucent phone system:
if this is a partner acs, AND it has a backup card:
From ext 10 or 11:
Press feature 00
left intercom
left intercom
#125
it should show a backup file. if none, the entire system will need to be completely reprogrammed
if there is a file there, you need to hit the enter button. the enter button is the 3rd button down farthest to the right.
the system will power down and come back up. time and date will need to be redone though.
Jan 21, 2008 | Avaya 700340193 Corded Phone
Avaya acs
easy w/ some more info. what release acs? no clue maybe... then you can "default" system which restores system setting to day 1 and you then se date and time , then assign ringing to phones after that. UNLESS you have Auto Attendant and / or voice mail card . other settings must be programmed in this case. -Bob
Sep 05, 2007 | Avaya Partner 34B Corded Phone
Lands Phones Logo
55 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
