Question about Mitsubishi WS-65907 65" Rear Projection Television
Mitsubishi ws-65907 tv not turning on
I manually push the power button and the green power light turns on and then turns off a few seconds later without the tv even turning on. So here is my email so you can send me what you have for a solution. mlmoate@yahoo.com I hope to hear back from you soon.
Thank you for your time,
Marcia
  • Blinkincrazy Dec 31, 2008
    Mitsubishi WS-65907 65 in. Rear Projection Television
    I manually push the power button and the green power light turns on and then turns off a few seconds later without the tv even turning on. So here is my email so you can send me what you have for a solution. Or post it steve@klassykoach.com I hope to hear back from you soon.
    Thank you,
    Steve
Let's just buy new TV's to help stimulate the economy.........
Posted on Feb 22, 2009
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws 65907
do u hear a clicking sound.
this can be due to relays getting tripped
Jun 22, 2008 | Mitsubishi WS-65907 65" Rear Projection...
I have a mitsubishi ws-65315. When I go to turn the tv on the green power light comes on and you can hear the tv click on, but seconds later shuts off.
this model has a self check, when green light comes on and then goes off. Push and hold both the Menu and Input buttons on the front of the set for at least 5 seconds and release both.
Power light will blink a two digit error code like 2 blinks 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Feb 22, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi ws-65511 tv won't turn on
If the green power light on the front comes on for a second or two and goes out: Press and hold both the menu and input buttons on the front of the set for at least 5 seconds and release both. Power light will blink a two digit error code: 2 blinks, 2 blinks, pause and it will repeat several times. Let me know if you find a error code and I will tell you what it means. IF this information was something you did not know, rate this solution as very helpful as I do this here for free. SD TECH
Sep 07, 2010 | Mitsubishi WS-65511 65" Rear Projection...
Tv not turning on
U know how to solders?Replaced the convergence ICS and all it resistors,should get ur power back.Tries Websites Tv repair World.com,Tvrepairkits.com.First check ur DM power board see not any burn parts first.
Jan 12, 2010 | Mitsubishi WS-65907 65" Rear Projection...
Turn it on and turns off again
sounds like your powersupply is bad. usually reasonable repair. 150-250 parts and labor
Jun 05, 2009 | Mitsubishi WS-65907 65" Rear Projection...
Mitsubishi ws-65907
can u please give me ur email ID so that i can send u a DOC file having all step by step instructions?
since it is very long i can post it here
Mitsubishi rear projection tv model ws-65907
Your problem is in the power supply section,,all the solder there holding the parts is crack or loose already need to resolder so performance will back again.
Jun 19, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi WS-55807 TV won't turn on
It s a Power supply problem.If you are not familiar with electronic repairs take it to an authorized repair shop.
To get a service manual see link
Download Mitsubishi WS-55807, WS-65807, WT-46807, WS-55857, WS-65857, WS-55907, WS-65907, WS-73907 Service Manuallockmanualsdnw_en.gif
Login or Register to get access all drivers database.
Please be sure to enable cookies.
Feb 21, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WS-65907 65" Rear Projection Television Logo
199 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
