Question about Maytag PYE2300AY Electric Dryer
Maytag quiet seris 200 Dryer
The dryer will start and run about 1 min. Then it cuts off. Some of the light around the dial flash
  • Maytag Master
  • 8,220 Answers
Bad motor.Replacing the motor is not that difficult and cheaper than buying a new appliance. We know the timer is ok and the fuse is not blown. The heat does come on and the door switch is ok. All it can be is the motor. You can sometimes get the motor going by oiling it. I drill out each end bell with a 1/8th inch drill bit being careful not to hit the shaft. I then pour in some heat resistance zoomoil. I work the motor free and oil the wheels and check the front glides. Oil the idler and hope for the best. Total cost to you $2 for the zoom-oil. Any ace hardware store carrys it. Hey it is worth a shot ain't it?Maytag quiet seris 200 Dryer - 4b58dda.jpg
Posted on Dec 16, 2008
Maytag quiet series 200 runs, dries but timer does not move and time out.?
Probably the timer motor is broken, or electrical connection bad. Probably need a replacement timer. OR something has wrapped around the dial shaft and is binding the dryer.
Feb 28, 2015 | Maytag Dryers
Dryer runs and stops and all l.e.d. lights come on
Was the dryer on that the time the power was cut? Was the dryer on when the power was restored?
It sounds as though it may have suffered a surge which may have affected the controller board.
Dec 11, 2013 | Maytag Dryers
I have a Maytag Heavy Duty /supersize capacity/Quiet Series 100/ 10 cycle dryer. It is not so Quiet when it is turned on, It has a very loud squeak for about 5-10 min. Then it quits and does not have A...
my daughter had same problem. maytag used to be build to last but no more. the dryer tub sits on the front lip around the door opening the support breaks and then the tub has no support and ride around rubbing on opening lip squeeking and causes a lot of friction and will either break the belt or a plastic piece on the motor. it broke all the above on my daughters dryer. we just junked it good luck
Sep 10, 2012 | Dryers
I have a quiet series 200 Maytag dryer. The dryer comes on but the drum does not turn?
Sounds like your belt broke. Here is a video to show you how to replace it if it is broken.
Here is a link to the part.
Nov 30, 2010 | Maytag PYE2300AY Electric Dryer
My Maytag dryer (model no. 3758AYW) makes a loud humming noise...otherwise it works. Vent was disconnected and it still hums continuously when turned on. This is supposedly a "Quiet Series 200".
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
This often indicates that the motor is going bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 17, 2010 | Whirlpool LER5636P Electric Dryer
Maytag quiet series 100 electric dryer clicking when I try to start. Pause light clicks on too.
my dryer clicks on then runs for 30 sec then clicks off and all the lites flash then it stays on the regular lite
Jan 30, 2010 | Maytag Dryers
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
My maytag dryer is blowing cool air
it should be located it a small trap door around the drum either on the side , inside , or on the bottom. to replace it you must remove the screws the hold it in place slide it out remove the wiring and then slide the new one in screw it back in and plug the wires back on it. please make sure during this process the dryer is unpluged from the wall plug. hope it works out for you .
Jan 05, 2009 | Maytag MDE3706 Electric Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Maytag PYE2300AY Electric Dryer Logo
99 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
