Question about D-Link DES-3226S (des-3226tg) 24x10/100 Mbps Networking Switch
Problem in VoIP - SIP with router D-Link
I want establish communication with ( VoIP-SIP) ,the élements of my Network are PABX BCM50, Router D-Link and Hypermédia, when I call à GSM from the phone connected to the BCM, the person with GSM hear me but idon't hear him. I think that the the problem comming from a bad configuration of SIP and RTP protocoles in D-Link, because I'am not competent on configuation of D-link.
Please help me,
Thank you.
SOURCE: lost network connection
how to connect you plz say more
Posted on Nov 17, 2007
  • 139 Answers
SOURCE: Won't allow connection to router
Since each of these devices is rated for 1000Mb/s, everything should be compatible. Make sure the NIC driver is up-to-date on your computer....and use automatic settings for speed and duplex wherever you have the option of setting it. The only other thing I can think of is to try a "crossover" cable between the router and switch...although this function is usually handled automatically in most modern interfaces.
Posted on Jan 10, 2008
  • 5 Answers
SOURCE: QOS on D-link dir-625
buy a linksys wrg series router and smash that dlink peice of junk into tiny little pieces, put them into a bag and mail to dlink, with a letter describing your opinion of their products.
Posted on Jan 31, 2008
oldnovii
  • 667 Answers
SOURCE: Cannot configure D-Link DIR 625 wireless router
Hey Raj - Unplug your modem and router. After 60 seconds plug your modem back in. When the lights return to normal (except the activity light) , plug your router back in. Give it 10 seconds and try it. If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be happy to assist you further. Thanks.
Jeff
Posted on May 31, 2008
SOURCE: Layer3
http://en.wikipedia.org/wiki/OSI_model
Layer3 is the Network Layer of the OSI Model, IP operates at Network Layer, OSI Model comprises of 7 layers, Application, Presentation, Session, Transport, Network, Datalink, Physical layers.
It is a model to follow when you are building Operating systems, applications to be used on the internet or compatibility with others.
Hope this helps
Mutahir
PS : Read about it on the wiki link i have provided, let me know for any other questions you may have.
Posted on Sep 26, 2008
What are the advantages of SIP for VoIP?
SIP (Session Initiation Protocol) is an application layer protocol that is based on IP. It is a major communication standard mostly responsible for VoIP (Voice over IP) telephonic system. In the traditional phone networks, ISDN (Integrated Services for Digital Network) is considered as the communication standard designed for the transmission of voice traffic. Both ISDN, and SIP are usable with equal reliability; however, in ISDN system, the clients need to pay for the data service, and voice service separately, while in the SIP system there is no separate charge for data and voice. Thus, SIP is just good for the customers as it decreases the telephone charges drastically.
Reliance Global Call-Enterprise is one of the most reliable and popular SIP trunk providers over VoIP. It helps to install SIP trunk at the organizational levels, enabling to cut international call rates like local calls. Moreover, the users can connect their landlines, as also mobile lines with the SIP trunk service for VoIP.
Feb 22, 2017 | The Computers & Internet
Why do I have one way sip audio on my belkinF5D7234 router
That router has compatibility issues with some VOIP modems which I am guessing you are attempting to use and that result in one-way SIP.
You may need to check if the router is compatible with your modem
Jan 27, 2013 | Belkin Computers & Internet
Is that mean D-Link DVG-G1402S router does not support VPN Server?
IT does Security • SIP Authentication with Password Encryption • Configuration Download Using HTTPS and SSL/TLS Clients Certification Encryption and Authentication • VoIP NAT Traversal (SIP/STUN) • NAT/Firewall (NAPT, TCP/UDP, DMZ, ALGs) • VPN Pass-Through • Packet Filtering by IP Address, Port Number, and Protocol
Mar 06, 2011 | D-Link DVG-G1402S Wireless Router...
Having issues with logging into the cisco softphone from home via vpn
Make sure that the subnet for the call manager is available over your VPN if you have locked the tunnel down. Also make sure that the IPC is allowed to bind to the VPN virtual network card.
Hope that helped!
May 19, 2010 | Cisco IP Communicator (SWIPCOMME1CH1)
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
E1 or T1 to pabx to router to softphone
Yes, configure second Cisco E1 port to simulate you telcom (network side) and connect it to PB, and first Cisco E1 to your telecom provider.
On Cisco router configure voice ports, and number manupilation, so you can catch any call and redirect it anywhere (Voip, Telco, PBX).
I tryed that with Ericcson, and it didn't work until connections where like these
telco <-> Cisco VoIP gateway (E1x2) <-> PBX
PBX's are not very flexible, Cisco is.
Jan 27, 2009 | Smart Modular 128MB SDRAM Module for Cisco...
Can't access voice tab on WRP400
If your wireless VoIP router was provided by your VoIP provider they will usually lock this option on the router since they have pre-configured the voice settings(sip server, phone number, password, codecs) before they deliver the device to your location. if you have a working internet connection already you can give your VoIP proiver a call so that they can remotely check the voice settings on their end to verify if it's working or not.
Nov 24, 2008 | Linksys Wireless-G WRP200 Router
Cannot access the internet through my DIR-625
Check your IP address to 192.168.10.1 on the network settings
after that turn modem and VoIP off.
Click on Setup / Manual Internet
Select Dynamic IP under "My internet connection is"
Click on "Clone Your PC's Mac address"
Click on Save settings, if it ask for reboot click on reboot
After the router reboots (NOT COMPUTER), it will take you back to the router.
Once your are in the router, turn the modem on first then the VoIP.
After the modem and VoIP has finish rebootin
Click on the status tab of the router and check uder the "WAN"
Settings and check the IP address. If you get an IP address then check the internet.
If you do not get an IP address Click on Release and then renew.
If you still do not get an IP address click on Advance tab
Click on Advance network on the left and turn UPNP off and save the settings.
After that it should be able to get an IP address and you should be able to get online.
Nov 05, 2007 | D-Link DIR-625 (790069292637) Wireless...
D-Link DES-3226S (des-3226tg) 24x10/100 Mbps Networking Switch Logo
62 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
