Question about Canon PIXMA MP510 All-In-One InkJet Printer
Small torn piece of paper jam
I can see the piece of paper and it is a very small piece; is there any way I can remove it by removing some part of the housing of the printer?
After getting out my instruction book and further assessing the problem, was able to remove a small corner of the paper and then the printer ejected the remainder.
Posted on Dec 15, 2008
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
It just keeps displaying there is a paper jam
Hi, Just follow these steps and check whether there is a paper jammed or no.:-
1. Press in the tabs on the rear access door to remove the door. 2. Gently pull the paper out of the rollers. IMPORTANT: If the paper tears while removing it, check inside the printer for torn pieces of paper and remove them. Additional jams are likely to occur if all of the torn pieces are not removed. 3. Replace the rear access door. Gently push the door forwards until it snaps into place.
Feb 13, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hi, how do fix a paper jam? 1st page printed ok, 2nd page jammed. I pulled it out backwards but the centre of the page was torn and a small piece missing. I can't see where I can clear that small piece of...
Unplug the power cord and open the cover and remove the TONER and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
Feb 11, 2010 | Brother HL 1240 Printer
Says it has a paper jam but there is no paper in it!!!!
Often there is a small piece of torn paper in the vicinity of the paper sensing switch lever.
OR the switch lever has been damaged by forcibly removing a paper jam.
You should open the printer and inspect the paper path for these problems.
Sep 01, 2009 | Dell V305w All-In-One R840635AU InkJet...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Apr 23, 2009 | Sharp AL 1631 Copier
Several sheets of paper are stuck. How do I get them out?
First remove any paper not loaded from the tray - DO NOT use force!
The following is from the HP Website:
Clear a paper jam from the back of the All-in-One
  1. Disconnect the power cord from the back of the product.
  2. Remove the rear access door: Press the tab to the right, and then pull out the door. Figure 1: Remove the rear door c00652942.gif
  3. Gently pull the paper out of the rollers inside the product. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  4. Replace the rear access door. Gently push the door toward the product until it snaps into place.
Dec 14, 2008 | HP Photosmart C3180 All-In-One InkJet...
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
96 people viewed this question
old marine
old marine
