Question about Refrigerators
Plugged fridge in during power failure to a lead from generator. smelled something burning and a clicking noise is heard from refrigerator. there seems to be a smell coming from the card in the back of the fridge
    Genius:
  • 2,920 Answers
The generator was too strong for the fridge
Posted on Dec 14, 2008
I plugged my fridge to a generator during a power outage. I heard a loud click and now the compressor will not start. The temp control lights are flashing. Please help
sadly the only one that can help is a repairman .since the compressors have freon in them and certified people are needed to replace
Aug 31, 2015 | Refrigerators
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore fridge started having sparks and has an unpleasant smell
the compressor is asealed unit and wont cause any smell but it does have a push on starter on the compressor pins under the cover (most likely cause)
Possible other faults are defrost element or defrost timer
Jul 27, 2009 | Refrigerators
Amana bottom freezer has a burning smell coming from the back of it. Fan is still working.
Is this burning smell occurring during a defrost? Something, like a food particle or wrappping, could be burning while in contact with the defrost heater. Is the burning smell coming from within the freezer? If it is coming from the outside and back of the box, unplug the box and investigate, or call a technician. You may want to call a technician, anyway? We don't need house fires.
Jul 07, 2009 | Amana ASD2326HE Side by Side Refrigerator
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Stopped working, burning smell, clicking noise while plugged in.
have a technician check it out. burning smell is always fire hazzard. A connection may have gone loose or connections are soaked.
May 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Clicking noise coming from refrigerator
If the "clicking" noise is from a relay on the board or compressor, it's likely th compressor would be cycling on and off.
It could be a fan blade (evaporator or condenser) hitting something. Both fans only run when the compressor is on. This should be addressed ASAP as it could be a wire it's rubbing on.
Finally, the noise could be caused by the refrigerant within the sealed refrigeration system. This noise is more of a nuisance rather than a mechanical failure.
Apr 27, 2009 | Refrigerators
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Whirlpool GC5SHEXN Side by Side Refrigerator burning smell
How long had it been plugged in when you started to smell the burn. What kind of burn do you smell, is it an electrical burning smell or a smoldering dust burning smell.
supertechks
Nov 21, 2007 | Whirlpool GC5SHEXN Side by Side...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
