Question about Panasonic PT-51G44 51" Rear Projection Television
Vertical size The vertical size on my tv is erratic. It gets "over-sized" at random times and it is happening more frequently. Trying to find a schematic for a tv's circuit board seems to be nearly impossible. Any ideas on why this would happen? I'm no tv repairman, but I repair circuit boards everyday fro a living. TV repair is new to me. I'm certain there must be an IC that controls vertical size, but I have no idea which one. Any ideas? Know of any way to get a schematic for this TV?? Thanks.
  • cory russell Apr 02, 2007
    The Model is Panasonic PT-51G44. I have replaced the vertical IC with some help from Panasonic's tech team. This didn't help. A week after, the vertical problem became the typical tiny line across the screen. What I really need is the schematic. I could not find it on the website Snakehead mentioned.
    Genius:
  • 1,074 Answers
Make checks on your vertical it could be getting too much voltage replace it along with some cap around that are not filtering the voltage to the ic.because it have cause damage to your vertical change all related components in that circuit also check the related circuits.you can get a schematic for your set at www.samsphotofact.com good luck
Posted on Mar 30, 2007
  • Henry  Thomas
    Henry Thomas Mar 30, 2007
    on a point of note you did not mention the make and the model of your tv and type.very important.
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
White lines at the top 3-4 inches of the screen.
well its all new now could be bad caps or vertical i.c. okay if you have a esr meter check around the i.c. for a leakey cap good luck
May 13, 2009 | Insignia NS- 27" TV27 TV
Inspiron 1525 Touchpad has a mind of its own
I would try using what they call a cool mat. It sits under your computer and plugs into your computer per USB. It helps keep the computer cool. They cost like 25 dollars.
Mar 26, 2009 | Dell Inspiron 1525 Notebook
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
27"tv sharp analog
Good day.
Refering to to mr walts inquiry and if it is, maybe you are having some issues in your vertical circuitry. It may be loose that it needs to be resoldered and other filter capacitors within the vertical section.
chris
Mar 22, 2008 | Sharp 27C-240 27" TV
Mitsubishi CS 40503 TV
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Oct 11, 2007 | Mitsubishi CS-40503 TV
Tv image
Hello bouloulou, Well let me tell you what you have is a loss of Vertical Linearity. This could be cause by a power supply issue or by inproper filtering of the dc voltage used to supply the vertical section of the TV. There used to be a control which allowed you to adjust this along with Vertical Size which controled the bottom of the screen. These days the signal processor chip takes care of this along with a few capacitors. I woould suggest that if you do not have a background in electronics that you take the set to a shop for repairs, If you do have a background in electronics, get a schematic for this set and the use your multimeter set to DC volts to measure the DC levels in the vertical section of the TV. Also you will need an oscilloscope to measure the ripple voltage on the DC power supply the schematic will show you how much ripple is allowed. I hope this helps. Thank you, Shuttle83
Oct 08, 2007 | JVC AV-27230 27" TV
Cable channels fuzz out
I think you have a bad connection in the tuner. The tuner is what decides what channel you get. It's a small box inside your tv about the size of a pack of cigarettes. These have been known to develop loose connections or just go bad. Some are pretty expensive depending on the type set you have. Since your set is older and you want it fixed you'd better get an estimae first. Stargazer
Apr 16, 2007 | Sanyo AVM-3659S 36" TV
Sansui - BOTTOM OF SCREEN CUT OFF
Your problem is not a vertical alighnment or size adjustment. No, Im sorry to say its the old vertical output IC and /or the small capacitors around the ic and in the vertical circuit. If you dont have the right tools, like a soldering iron a multimeter know how to read a schematic diagram, then you should seek out a repair person to assist you in this repair.
Sep 12, 2006 | SansuiS2001 20" TV
Panasonic PT-51G44 51" Rear Projection Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
