Question about Roper RGX4634KQ Gas Dryer
Dryer not heating
We had to move the dryer out of the way yesterday (about one foot) to make room for the new washer, but only had to unplug it and disconnect the vent - the gas remained connected and on. Moved the dryer back in place, plugged it back in and reconnected the dryer vent, but now it is not heating. Any ideas?
  • 71 Answers
If you jarred it , you probably broke the ignitor I can help you with this and help you get the parts
Posted on Dec 14, 2008
I moved my Cabrio electric dryer to another room. A new outlet was installed in the new room. When first plugged in, the dryer runs and tumbles but will not generate heat. Suggestions?
Your electric dryer uses110vac to run the motor which makes the drum turn. It uses 220vac to run the heating elements. I'll assume you had a qualified electrician add the new outlet. If not, I'm betting whoever did the install used the same electrical phase for both 110 sides of the plug. You can't use an electrical tester to test this as both sides will read the same. Manually trip the breaker (should be a double breaker) and then check the outlet. The wiring to the hot leads should be black on one phase and red on the other. Let me know what you find out
Oct 18, 2013 | Whirlpool Cabrio WED6400SB Electric Dryer
Dryer stopped drying yesterday.
www.RepairClinic.com
Sounds like the heating element quit.
Jan 25, 2012 | Splendide 2100XC
Dryer Maytag LDE 9316 ACE -what is the capacity of that model dryer? Thank you!
Capacity is a key consideration when shopping for a dryer. The more you are able to dry in a single load, the less time and money you will spend doing your laundry. Most importantly, look for a dryer with approximately twice the cubic foot capacity of your washer.
Typical dryer capacity ranges from approximately 3.4 cubic feet (for a compact model) to over 7 cubic feet for an extra large capacitor
In addition to saving time by drying on fewer loads, and money on lower energy costs, a large capacity dryer often means spending less time once the laundry is dry. There is typically less wrinkling when clothes have more room to move around inside the drum.
Whirlpool brand offers dryers with a range of capacity and flexibility.
Dec 16, 2010 | Dryers
No heat in dryer
Check the wiring first. If that looks ok unplug dryer from wall then remove the heating element and test it for continuity. If it is wide open then it is bad.
Jun 18, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
We moved our whirlpool elec dryer to another room and now it will not heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | Whirlpool GEW9250 Electric Dryer
Longer cord/age of washer & dryer
Is your dryer electric with the big plug.
If so, what kind of changes are you making?
The dryer needs to be by the vent outlet so you can't move it far unless you are going to cut a new venting outlet.
If it is electric (not gas) then do not try to extend the cord. Have a licensed electrician move the electrical jack.
The cord has a large amount of current running through it and the longer the cord, the more resistance the current has to flow through. More resistance means more heating of the cord and less voltage for your dryer. This can result in the cord overheating to the point of melting and starting a fire itself or getting hot enough to ignite the very fine and very dry lint particles that are present in any laundry room.
This is a situation where you spend the money and have it done professionally because of the danger of fire, death, etc.
Good Luck!
Oct 09, 2009 | Dryers
Hotpoint Aquarius wd440 washer/dryer wont pump out water HELP!
Try unplugging the unit and plug it back in. This may reset the controls.
Jun 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Kenmore Dryer 62802 Doesn't Heat
sounds like the heating element has gone south
if you open up the dryer you can check continuity across the element but make sure power is unplugged
Apr 13, 2009 | Kenmore 62802 Electric Dryer
No Heat
Make sure that there are no kinks in the export for heat (usually a tubular plastic device that exports the evaporated water out of the machine) and that it is properly attached. If this does not work, check to make sure that you did not break a belt in the dryer. If it is old a new belt may need to be replaced. See replacement instructions if necessary.
Jan 13, 2008 | Kenmore 95087 Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
41 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
