Question about Whirlpool LEQ9858P Electric Dryer
Whirlpool Electric Dryer LEQ88ooJQ1----I think it's the belt.
I have pulled off the back off the dryer and took off the vent casing and all I see is the fan and I don't see the belt anywhere.
I believe it is the belt that is busted because the dryer will turn on and the heat works but it will not turn the clothes.
  • 71 Answers
You have to pop the top and take the front off to change the belt. there is two clips you can press with a putty knife ,about 3 inches from each side on the front under the top . This will release the top. Now check the belt on the drum. If it is whole the problem is the idler pulley . I can help you and supply the parts you need cheap
Posted on Dec 14, 2008
How do I remove the back of my My Kenmore 700 Series dryer
unplug the dryer,pull it out away from wall enough to disconnect the vent line,remove the vent line and pull the dryer out,remove the screws from the back panel that's it.what are you trying to do?
Mar 21, 2013 | Whirlpool LER4634J Electric Dryer
My cabrio dryer wed7600xwo is no longer drying right, I have to run loads 3 times to get them dry. What could the problem be?
This dryer has 2 belts. A smaller belt operates the blower. The nut tends to back out and the small belt falls off. Here is the result:
Bravos dryer innards of a failed blower belt
Look around on my foggy site for your service manual. Let me know
Feb 22, 2013 | Whirlpool Cabrio WED7600XW Electric Dryer
When the dryer is turned on it makes a humming noise. The bin inside turns manually. Cleaned out vents took the back off and back off and vacuumed the back. Is there a belt? Dryer is less than 2yrs old
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 28, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Whirlpool condensed tumbler dryer
check ur dryer vent in the back u might have pushed it back too far and kinked the hose ar u might have a buildup of lint in the dryer vent pull the dryer out and take the dryer vent off and run a load of clothes like this if it works look for a lint buildup in the hose or u just had the hose kinked
Feb 26, 2010 | Whirlpool LER5636P Electric Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
How to install a belt on a Whirlpool dryer model LEW0050PQ?
The tech I paid to replace the belt opened the case from the top and the back, and pulled the drum back away from the front, keeping the drum attached to the back panel. This exposed the motor and the broken belt, which had been cut by the motor drive wheel, probably because the drum was too heavy. Don't you just love renters?
Mar 26, 2009 | Whirlpool LEW0050P Electric Dryer
Whirlpool electric dryer not heating
I had the same problem today. After stumbling through the schematics (they were taped up behind the main control panel on top of the dryer) and ohming out a bunch of different parts with my multimeter, I finally took the heater element out and found that it had burned in two in a spot (I could see it once I took the element off of the dryer). I replaced it for about $80. The guy at the parts store said that is usually caused by a clogged vent, which is probably the case for mine, since my vent is poorly designed. I hope this helps someone.
Nov 07, 2008 | Whirlpool LEB6300 Electric Dryer
Putting dryer back together
if whirlpool are kenmore the pulley slides in tobottom of the dryer in front motor there a slot it goes in
Dec 24, 2007 | Kenmore 64952 Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
41 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
