On final spin water not draining out
On final spin water not draining. I have to wring out water from clothes before putting in dryer.
  • Washing Mach... Master
  • 3,463 Answers
If the motor and drum are going round, then you probably have a blocked pump.
Check outflow of water from m/c, check filter if you have one. m/c will not spin if a lot of water in.
If still no spin then problem could be any one of a number of things.
Plz rate my solution.
Thanks.
Posted on Dec 14, 2008
Ge toploadwasher that does not get water out of clothes after final spin
Could be that the spin cycle is not rotating at the required speed to wring out your clothes. Check that the cycle completes at a significant speed to generate centripetal acceleration forcing out the water. Perhaps the load is unbalanced which can trigger the spinning cycle to repeatedly stop during the spin cycle.
Jan 31, 2015 | GE Washing Machines
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
MY WHIRLPOOL WTW5300SQO WASHING MACHINE WONT DRAIN WATER THE OTHER DAY IT WOULD NOT SPIN TO WRING THE CLOTHING THERE WAS A SMALL GARMENT LODGED IN THE SPIN BASSIN(?) WE TOOK IT OUT NOW THE WASHER WILL NOT...
Could be filter is blocked. Or drain pipe is blocked.
Fact it wouldn't spin, could point to blockage, as spin won't start if too much water in drum. Bad news is, it could be the water pump needs renewed.
Make sure drain pipe is properly connected to the waste pipe, and clear of obstruction.
Jan 16, 2013 | Washing Machines
My daughter has a new Whirlpool WTW4800XQ0, it takes the machine about 3 hours to go through the cycle. Okay this being said, when it gets to the spin cycle, it doesn't, she is having to pull the...
does it drain water, seems like it's gonna spin then starts filling up again? if this is what's happening it mean the washer is sensing that the load isn't balanced and it fill back up to move the clothes around and tries again, it will keep doing this untill it senses a balance of weight in the drum. if she tries moving the clothes around herself before it done draining she maybe able to keep it from doing this
Aug 05, 2011 | Whirlpool WTW4800XQ Washer
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Sometimes the spin cycle works and sometimes it doesn't. The water is draining, but sometimes the clothes are still very wet and I have to wring water out of them before I put them in the dryer.
if that is a top load whirpool suspect transmission..the transmission is designed to drain first and then after another timer pause go into spin sometimes after the pause they fail to do so it is a hard problem to verify without a lot of patience..put washer into final rinse allow washer to complete cycle on it's own DO NOT MANUALLY ADVANCE TIMER OR OPEN LID if possible you can raise lid and hold lid switch down.. after agitation there should a short pause then pump out then another pause and spin should engage if you do not here spin raise lid then shut if spin starts change transmission..on rare ocassion have seen timer never pause then change timer if this is only occasional may be hard to spot and may require more than 1 attempt to catch it..good luck
Sep 07, 2008 | Washing Machines
Tub will not spin
very possible there is a blockage in the drain pump.
Oct 24, 2007 | Washing Machines
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
