Question about Mitsubishi VS-6041 60" Rear Projection Television
Broken screen I have a mitsubishi vs-6041 and have broken the screens. wondering if any one has one for sale or know where i can buy one. it is a 60 inch tv thanks
  • 3130 Answers
SOURCE: Mitsubishi Bi Screen VS-6041
Go to Good luck
Posted on Jul 31, 2006
SOURCE: Mitsubishi VS-6041
wondering if you still have this i would like to buy it from you and wher u are locatred
Posted on Mar 15, 2007
Laurens mom
SOURCE: Mitsubishi WS-55807 parts in a VS-60603?
I own a Mitsubishi WS-55807 55 in. for parts if you are interested. Please contact me back if interested. 727-773-8208 Nicole
Posted on Feb 22, 2009
  • 563 Answers
SOURCE: I have a Mitsubishi hd 1080 series 60 inch model # vs-60111
What you're describing is a repair issue. Unfortunately, there is nothing you can do through troubleshooting to correct that problem. There is an internal part that has to be replaced. If you're under warranty or have an extended service plan, the repair will cost you nothing.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need further assistance so that I can help you further.
Posted on Jul 11, 2009
SOURCE: mitsubishi vs-50603 no remote.what is code
Posted on Oct 24, 2009
  • 55 Answers
SOURCE: Need to disassemble Mitsubishi VS-6041 60 in Rear Projection
1st TV is cool, 2nd Remove the Front lower speaker cover by pulling left and right ends toward the front there are upper and lower plastic hold pegs on each side 3rd remove the panel located between speakers 4th remove All screws out of plastic control cover located just below channel,volume ect... 5th remove anything on top of the VS-60705 DVD,VCR,Cable boxes est.... 6th gently lift each top corner of Plastic Screen Frame. take note: there are 2 pegs at the middle of each side of the screen frame and 3 hook mounts at the top of Screen Frame. The top Hook Mounts flex wraps around top Screen cover, where the side hooks just rest on the TV housing. 7th Lift frame up and the Screen Frame Releases and place on Ground in front of TV. Remember The Screen is PLEXI GLASS and if you remove the Frame and allow Screen to bend it will BRAKE and you are Totally Screwed....!!!! So just be nice and do not Bend, Walk On, Drop Tools or Hammers onto...!!! 8th Remove Rear Dust Access Cover Screws Remove Cover 9th Get Wet/Dry Vac and Use A Clean Paint Brush and began to Brush Circut Boards while Blowing The Dust Out and Off of TV. Clean Inside Projector Lens With Glass Clean, I spray onto Soft Cloth and then Clean inside of Projection Miorror I use Paper towls and then inside of Screen Sitting on Floor 10th I put the Front Screen Back on ready to mount but i take and blow any dust off with vac and then lower Fame back onto mounts making sure the 3 top flex mounts lock and frame is flush with TV case,Replace screws next, then middle panel back on then speaker covers pushes back into Mount Plugs. 11th I then got to rear and wipe off the Projector Lens one last time and put the rear dust cover back on....Cresto" wow like brand new"....make sure you brush dust off because moisture loves dust and then makes a unwanted Ground and POW something just Smoked...!!!! hope this helps anyone out MERRY CHRISTMAS" ....Our Savior IS BORN Happy Birthday JESUS"
Posted on Dec 17, 2009
0 characters
1 Points
Does anyone know anywhere to buy a screen for the tv. Ours is cracked badly
This is an older projection TV & I am unable to locate the parts for it, best bet may be to search craig's list for someone locally trying to get rid of one that may have a good screen
May 13, 2014 | Mitsubishi VS-6041 60" Rear Projection...
Tv screen broken
Call TV shops ask if they have any for sale and look on Ebay under Electronics and Encompass Parts Distrubtion has them sometimes 1-800-638-3328
Mar 25, 2010 | Projection Televisions
Mitsubishi VS 6041. Just began having problems
Replace Both of your STK ICs example STK394-250 they are big black ics will have part number on them Call Mats 1-800-628-1118 for parts.
Sep 16, 2009 | Mitsubishi VS-6041 60" Rear Projection...
1995 mitsubishi big screen vs-6041
I have a copy of the owner's manual for my 6041. If you would like, I can scan it and email it to you.
--Ralph Dowling
Feb 02, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-6041 60 in. doesn't power up
Hello Tremulant
This denotes a possible problem with the Low or high voltage power supplies. The clicking you here might be the shutdown circuit acting because of excessive draw of current. The problem will most likely be associated with the HV power supply, but you will have to have a qualified TV technician check your TV to make sure.
I hope this helps,
Thank you,
May 31, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Focusing the VS-6041
If your set is out of focus then this is a sign that it is having internal problems. I would do the self test to see what error code you get if any. Search threads for this or
Jan 01, 2008 | Mitsubishi VS-6041 60" Rear Projection...
Probably bad connections on yoke plugs, have a qualified shop do repair and alignment who knows what yoke plug repair is
Dec 20, 2007 | Mitsubishi VS-6041 60" Rear Projection...
Mitsubishi VS-6041
Nov 08, 2006 | Mitsubishi VS-6041 60" Rear Projection...
i have the same problem. broke during move. i'm just beginningmy search. let me know
Jul 31, 2006 | Mitsubishi VS-6041 60" Rear Projection...
Projection Televisions Logo
23 people viewed this question
Top Mitsubishi Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Projection Television Expert? Answer questions, earn points and help others
