Question about Canon Rebel XT / EOS 350D Digital Camera
My camera won't take a picture
The camera will focus and beep (and the flash will pop up if needed) whe we push the button halfway down, but when we go to finish clicking the button, it won't take the picture. We often receive a busy flash message in the display window as well.
  • 1 more comment
  • Anonymous Dec 30, 2008
    mine does this when the telephoto lens is too close to something, which i understand.
    but what i don't understand and need help with is this: i have a blank background [like a sheet or something all the same color] and no matter the distance from it, the camera does this. it won't take a picture with "no subject matter". it's really frustrating because i'm trying to use it for self portraits.
  • Anonymous Jan 31, 2009
    i go to click the button to take a picture and it acts like its going to, but then it don't!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Dave Long May 11, 2010
    Please confirm if this happens all the time, with a particular lens, a particular distance.
    Are there any indicators flashing in the viewfinder?
This is the same problem I was having. I simply removed the lens and flicked the internal mirror with my finger nail a few times. The camera then worked fine.
Probably, our cameras need a good cleaning. My guess is the issue is that some internal moving parts are a bit jammed up with dust or other crud. When I flicked the mirror it freed it up. I don't think that this will be a permanent fix, so I'm scheduling the camera for a professional cleaning
Posted on Feb 09, 2009
Shots are blurry
This issue can occur in the following circumstances:
The subject is too close to the camera lens Insufficient lighting Subject movement Camera movement Incorrect camera settings Incorrect camera operation Follow the steps below to help prevent taking pictures that appear blurry, out-of-focus or distorted.
If the camera has both an auto focus and manual focus mode, make sure it is set to auto focus. Make sure there is enough lighting to allow the camera to focus on the subject. Make sure the camera settings are set appropriately. When taking close-up or macro-type shots, ensure the subject is not closer than the minimum focus distance of the lens. Also, if the camera has a zoom option, set it to the W (wide-angle) position. If you have a fast-moving subject and the camera has a Program AE mode with a higher shutter speed (such as Sports action), make sure it is enabled. Also, if the camera has an ISO control, set it to a higher setting. If your camera has a SteadyShot/anti-blur function, ensure it is enabled. Aim the camera at the subject. Press the shutter button halfway down. NOTES:
Pressing the shutter button halfway down allows the camera to focus automatically. A flashing green indicator will be visible in the LCD or viewfinder. When the indicator stops flashing, focusing is finished and the camera is ready to take the picture. Some camera models have a Monitoring AF setting that can be selected which allows the camera to focus without the need to hold the button halfway down. Consult the instruction manual of the camera for information whether or not this is applicable for your model.
Jan 01, 2011 | Cameras
The flash pops up, but it doesn't flash
It is normal that when you press the shutter button half the flash won't fire because you're focusing on a subject upon pressing the shutter half way
It's just like you are locking a subject upon pressing the shutter half way
Aug 23, 2009 | Canon PowerShot S1 IS Digital Camera
Takes a long time to focus / take a picture
According to your description, I would like to assume that your camera takes 9 seconds to get the flash ready, not to focus. If it is the focus problem, you need to send the camera for realignment or to replace the lens.
Here is my suggestion:
Try to disable the flash. Does it still take 9 seconds to take picture? If the answer is ‘no’, then try to use fully charged batteries or new batteries to reduce the flash charging time.
If you have a ‘batteries drain quickly’ issue as well, this tip may help: Why my camera keeps saying ‘change battery’ even with new batteries?
Jul 01, 2009 | Canon PowerShot S5 IS Digital Camera
Have to press button down twice to take shot
This is your first SLR?
The normal procedure is to press the button halfway to get the focus. This is indicated by one or more red LEDs lighting in the viewfinder and a confirmation beep. Once you have this, you press the button fully to take the shot.
As the camera will not take a photo when not in focus, then pressing the button once and letting go will focus it, and pressing it again will take the shot.
Get used to pressing it halfway before taking your shots and it will soon become second nature to you.
Feb 11, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Autofocus will not work,
Camera wont let you take a picture until focus is locked, why are you using M (manual focus) if you expect autofocus to do it for you? In M mode it is up to you to focus correctly or camera will not take the picture.
Apr 13, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Delay in taking pictures
Shutter release button has two positions. Auto focus function activate first when u press butten halfway(u can see a focus indicator icon with beep sound).Now if u press it some more, camera will take snap at earliest .So pl confirm the subject to be focused by keeping the button half way pressed then press it some more at the right moment.Also cancel the red eye reduction function when u r using flash because it creates more delay .
Nov 26, 2007 | Canon PowerShot A540 Digital Camera
Wont speed up even with new batterys
The shutter button features a two-stage action. shutter_button.gif Pressing Halfway Pressing halfway automatically sets the exposure, focus and white balance.
The indicators light or blink as follows.
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
Sep 24, 2006 | Canon PowerShot A400 Digital Camera
Problem with image
What mode is the camera in? is it in "Auto" at the top there is a dial switch it to auto and press button halfway (shutter button) when you press the button halfway the camera will beep and display a square box on the LCD. If the camera beeps once and the box is orange it could not focus and you need to retry pressing halfway again. When it is in focus it will beep 2 times and it will show a GREEN box. This is the indication it could focus on the subject correctly. Its a machine and sometimes it takes it a bit for it to figure out what your wanting it to do. Its the nature of the unit
Apr 03, 2006 | Canon PowerShot A85 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
232 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
