Question about Canon CanoScan LiDE 30 Flatbed Scanner
Computer says Scanner not connected
Your reply: "try plugging the USB connection at the back of you computer.If still didn't work out, delete the old driver install the new one, besure cables are connected and intact. If still didn't work out bringyour scanner to the service center near you" helped. Now it is working. Thank you, very much.
: i just installed and rebooted
Posted on Jan 26, 2009
Lexmark X4550 Scanner not working
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 05, 2012 | Lexmark X4550 Multifunction Wireless Color...
Do i need software like ocr so that the lexmark x6650 scanner can work
If you are scanning documents for editing or saving them as PDF, you will need to install the OCR scan software. The Lexmark OCR scan software is available only on the installation disc that came with your printer. If you lost the disc, please contact Lexmark Technical Support Center to request for one.
If your scanner was working before, it could be just a slight communication problem. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
  4. Reboot computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to scan a document again to verify that the problem is fixed.
Nov 02, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
When I press the scan button, the error USB not connected appears even though it is connected.
You will need to install the software that came with the printer on the computer that it is connected to. The software will then run on the computer and "listen" for a command when you press the scan button. What is the make/model of your printer?
Feb 28, 2011 | Computers & Internet
Cannot transfer photos to computer, the computers reply was error in connection or scanner or camera is busy try back later. HELP
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Aug 21, 2010 | Samsung SL620 Digital Camera
I haven't used my scanner for some time and now it won't work. A message says can't communicate with scanner, check scanner, may be not connected. we took it with us this winter but have checked all the...
Hello.
Either the driver is corrupted or the scanner component is faulty.
Reinstall the driver for your device. If still a problem and the other functions work, but not the scanner, the scanner part is faulty.
Hope this helps.
Apr 10, 2010 | Canon PIXMA MX310 All-In-One Printer
Scanner does not work
Try uninstalling the scanner driver. Then unplug the scanner. Reinstall the scanner driver on the computer and then plug the scanner back in (USB connection).
Jul 30, 2009 | Canon PIXMA MP470 All-in-One Printer
I am trying to reinstall HP Scanjet 5400c but it keeps telling me it can't initialize, no scanner recognized...WindowsXP.. it worked before, why not now?
I had similar problem with my UMAX scanner on numerous occasions. I now have this pg earmarked for quick reference! may help I don't know for sure but it is an easy test and if it works your good to go!
It is important that you connect the scanner's power and USB cables in the following order:
1. Plug the power adapter cord into the scanner and into an outlet. The scanner's power will then be on.
2. Connect the USB cable to the USB port on the
back or front of the computer.
NOTE: If you unplug the scanner's power ,you must also disconnect the USB cable from the computer. To resume use of the scanner, remove the power card, the the USB cable.
Sounds like a lot but the order is essential!
If it works, High lite Do unplug USB/unplug cable back of scanner/and plug cable back of scanner then USB!
Good Luck Hope this helps!
Mar 26, 2009 | HP ScanJet 5300C Flatbed Scanner
Visioneer 9220 wont work
Dirty USB port. Try another Port. One of the 4 contacts is not making connection.
Mar 16, 2009 | Visioneer OneTouch 9220 USB Color Scanner
try plugging the USB connection at the back of you computer. If still didn't work out, delete the old driver install the new one, be sure cables are connected and intact. If still didn't work out bring your scanner to the service center near you
Dec 14, 2008 | Canon CanoScan LiDE 30 Flatbed Scanner
There is no computer connection
If it is connected with a USB then you should try to refresh all the connections. Unplug the printer while it is on and then unplug the USB from both the printer and the computer. Wait 30 seconds. Plug the printer in directly to the wall outlet as opposed to a surge protector or a power strip to make sure it is not a power issue. Then when it is on and finished moving around plug USB into the printer first and then into the computer.
Then you may need to delete and readd the printer but try to print a job first and see if the same error comes up. I can tell you how to delete and readd but I have no idea what type of computer or OS you are using. Mac 10.4? Windows XP?
Feb 23, 2008 | HP OfficeJet 6310 All-in-One Printer...
Canon CanoScan LiDE 30 Flatbed Scanner Logo
50 people viewed this question
old marine
old marine
