Question about Frigidaire 24 in. FDB1050RE Built-in Dishwasher
Frigidare Gallery Pro Dishwasher Control Panel Power
I have a FrigidaIre Gallery Professional Series Dishwasher Model: FDB989GFC1. The dishwasher lost power in the middle of a cycle. After some research I assumed it was the Control Board which I receive yesterday from Appliance Part Pro. Part#AP2109325 (154320603). I replace it and still have no power or lights on the panel. I checked the Latch Switch prior to ordering the board. The continuity appears OK. I even jumped the wires to be sure. Power is getting to the board through the White wire that connects to the switch. Could the Transformer be bad and power still be received at the White power wire that connects to the switch?
  • thom2 Dec 15, 2008
    Ronnieh49:
    Please read the post again. Note the line "Power is getting to the board through the White wire that connects to the switch."So your responce doesn't answer my question. Again--120volts POWER IS GETTING TO THE CONTROL BOARD, BUT I GET NO LIGHTS OR RESPONSE FROM THE CONTROL KEY PAD.
    I don't understand "USE EXTERNAL TRANSFORMER". Maybe I should haven't mentioned the TRANSFORMER in my question. I just looking at all possibilities. SIMPLY--- 120 volts of Power is getting to the NEW Control Board and through the LATCH SWITCH. The Touch Pad has NO LIGHTS or RESPONSE. I have ran continuity on the Latch switch, it appears good. I have inserted a photo of the Control Board. NOTE all WHITE WIRES have voltage.
    President:
  • 373 Answers
It can be the problem with the transformer. Try replacing it with another one.
Posted on Dec 15, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
No schematics or wiring diagram available my end. However based on your description and a couple of ideas you may want to explore:
  • Could the Transformer be bad and power still be received at the White power wire that connects to the switch? - Yes;
  • if the transformer is separate from the the Control board, then it has to be checked. Basic test is continuity, the windings connected to the 120 should read high compared to the opposite winding that goes to the board. I suspect this transformer supply the 5 and 12 volts needed. +5 for the logic circuitry, +12 to energize the relays;
  • in some versions of Frigidaire, there are two (2) door switches.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Frigidaire Master
  • 19,396 Answers
If you cnnected the new control board, the control board gets voltage, and machine stays completely off (no power at all), then the control board had blown again, test fuse and components.
If the control board had blown (the new one) it may be a problem with AC supply stability, a short or a wiring problem.
If there is no power at all to the board instead, check wirings.
If the machine is instead on standby mode, with power, but not cycling at all, check the door switch wiring.
All repairs must be done by qualified pesonell.
Thanks for using Fixya,
  • Sheila Briner Sep 26, 2011
    had a repairman come to replace the drain pump; but now the controls work backwards (you have to choose the cycle when the door is open; whe you close it, no information shows up); however, it runs; he couldn't figure it out, said he would have to call frigidaire. Any ideas? was thinking there would be some kind of reset button
  • 470 Answers
The problem is totally the transmit capacitor and the transformer that will create the function to it, you need to replace it..
    President:
  • 2,110 Answers
Remove bottom cover, there is a square aluminum box ,remove cover, the power wires are there, there should be two marrete conectors, carefully remove them, check for burnt wire, if you have a multimeter, check to see if you have 110 volts across these 2 wires, be careful these wires will be alive if breaker is good, if there is voltage the problem could be door switch in control panel.
Posted on Dec 14, 2008
    Master:
  • 479 Answers
It has to be checked with the continuity and meter to get the exact faulty fart.mostly it could be rthe transformer,check it out.
  • 734 Answers
Yes might be,
Take a try using a external transformer to your dishwasher.
Thanks
    Genius:
  • 2,920 Answers
Yes the power can be bad at the trransformer and not allow power to get to the main board
Frigidaire gallery stove
Hello mnwpictures - Based on the symptoms you are describing the range may either have a faulty EOC (electronic oven control) or a potential wiring failure. Try resetting the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and then turn the unit back on. Does the control panel have a display? If the issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
May 12, 2013 | Frigidaire Professional Series 24 in....
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
Our 4300 series frigidaire dishwasher has all the lights flashing on the front panel tried resetting power but did not hel[
sounds like its the p c control . it will need to be replaced . less expensive than most. ( inside the contrl panel is a tec sheet and it will tell you what the flashing is caused from ..ck the beeping for a code like dot dot --pause or 3 dots and a pause . this control has codes .. mm
Nov 22, 2009 | Electrolux Frigidaire Professional Series...
Started to get a clicking noise from the electic panel of my Frigidare PLDB998 dishwasher for a few loads and then it went dead. Its only a few years old
Did you ever find a solution? I have what sounds like the same problem. The time keeps ticking down but it flashes between CL and the time while the clicking sound is going, and it sometimes make a clunking sound while this is happening as well.
Sep 15, 2009 | Electrolux Frigidaire Professional Series...
Frigidaire professional series dishwasher has a lock symbol
did you try holding that button for 3 secs, it should unlock it
Mar 04, 2009 | Electrolux Frigidaire Professional Series...
Loose handle on frididaire gallery series dishwasher
Handle needs to be replaced part# 154537303 (blk). Un plug unit, take 4 screws from behind blk control panel out. Panel will fold down, remove two torx head screws from door latch, replace with new one and put it back together and your done.
Dec 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher won't start up
this could be a problem at the electrical hook up ,also could be a open door switch or if there is 115 volts to the control board and nothing happening then you need a board.
Nov 22, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare dishwasher
can you give me the exact model # on your dishwasher and i will check for you.
Sep 03, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidare Gallery dishwasher GLDB958JS0
Fault in the touch pad-replace the touch pad.If problem continues you have to replace the control board.
May 25, 2008 | Frigidaire Dishwashers
Frigidaire 24 in. FDB1050RE Built-in Dishwasher Logo
599 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
