Question about Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
I started to do a load door closed and then just a beep with a signal of f22. i now cannot get the door to open
  • huntinshack Dec 15, 2008
    Same problem here. Did you get yours to open?
  • Anonymous Dec 15, 2008
    washer door won't unlock
  • 26 Answers
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
cannot get washer door to open. - fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Posted on Dec 19, 2008
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
Jun 28, 2012 | Washing Machines
Kenmore elite he3t washer door will not open, always showing as f22 error code
it is your safety latch on your door. On the front load washer it will lock the door and if there is a problem with the latch it will keep it closed to prevent injury. If you have cloths in there try unplugging for about fifteen minutes or so and then plug it back in.
May 07, 2011 | Washing Machines
Close door, f22 message, won't start
"F22" is a door latch error. The following link explains:
http://www.fixya.com/support/r1976388-f22_error_code_whirlpool_duet_kenmore
Read through all the steps listed and let me know if you still require assistance. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22, washer is locked and will not unlock
IT is a defective lock, unplug the machine for 30 minutes and plug it back in. Then once the door opens replace the door lock and all should be well
Apr 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
Jan 16, 2009 | Maytag MAH6700AWW Neptune Front-Load...
F 22 front door locked and door won't open.
hi there,
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
Sep 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Sep 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
366 people viewed this question
Dan Webster
Dan Webster
Sal De
