TV colour programmes replayed in my video turn out in black/white
My video recorder turn colour programmes into black and white, even tapes that are produced commercially.
  • Anonymous Mar 13, 2009
    when connecting pc to tv via liteon dvd recorder using s video cable image turns to black & white.
    s video ok when connecting direct to tv.please can you help me
Fixed the VCR problem. Thightened all the connections and it now seems to be working OK
Posted on Dec 15, 2008
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
How i can watch the videos in the TV in colour is only black and white
If the videos are recorded in black and white your out of luck. If your trying to watch videos recorded in color on a black and white tv, get a color tv.
Comment if you need additional assistance or to provide more info.
Aug 05, 2011 | Iomega ScreenPlay Director 1TB HD Media...
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
Playback is black and white
if this is b/w on the tv then you have a settings problem.
you need to check you connected the camcorder to the tb correctly, it should be yellow for video and red and white for audio, and you could try looking at the tv menus
if its the camcorder then check the cc monitor. and all the settings. Get anew dv tape and record something , check its colour then play it through the tv.
Sep 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Replays both dvd and video tapes back in black and white only.
Check the av channel you are playing back on if it is av2s then this will play in b/w,you need to be on av2
Aug 09, 2009 | Televison & Video
On replay black horizontal line
Probably the video head has to be cleaned - you should give it to a local camera service center. I don't recommend using the cleaning tapes.
Hope this helps!
Jul 29, 2009 | JVC GR-D73E Mini DV Digital Camcorder
When we plug anything into the av1 we loose colour
Check to see if the cable is properly connected. Both on the TV, Video and DVD points. If it's a SCART, does it have a small switch on it? Also check settings to see of there might be a PAL/NTSC issue.
Nov 26, 2007 | Televison & Video
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Everything's in black & white
are you using the s video socket if so you will get black & white picture you need to use rca phono to rca phono or rca phono to scart lead to record to dvd burner. as I do alot of copying over myself i never use s-video socket due to cable wrongly wired for colour just black video signal. hope this works for you
Aug 14, 2007 | Mitsubishi HS-U778 VHS VCR
Jvc 200u problem recording to vhs video tape, from camcorder
Yes, if the camera is a US camera then it is NTSC. That would be your problem, you are trying to record an NTSC signal to a PAL video. THe frame rates and resolutions are all wrong. I am even surprised that it is playing back on your TV okay...
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
