Question about Kenmore 62602 Electric Dryer
Beeping sound in Kenmore series 90 dryer (110.609.12990)
Please help
A beeping sound has been going off in my dryer, every 30 seconds for the last month. Its driving me crazy :-)
My light bulb is also out and read that it is linked to the thermistor, so I will replace it. My wife says the bulb has been out for a year...so, any idea if I am on the right track? Thanks in advance
DJ
  • darryljones0 Dec 19, 2008
    Pauls44: Thanks...but I just replaced the light, and the problem still exists. any advice on next steps? Thanks so much
    DJ
  • 157 Answers
You are on the right track
Posted on Dec 19, 2008
Dryer starts about 45 seconds into the cycle lights come on and then it starts beeping like the end of the cycle. 10 seconds later off. Very warm on top of the machine.
See my tip for buzzing dryer. Check Owner's manual, Troubleshooting. Sounds like air is not moveing and High temp cut off saftey switch doesn't like the lack of air flow. Duct clean? Check air flow from the outdoor vent. Clean vent tube/s
Mar 04, 2015 | Kenmore Dryers
Why does kenmore dryer model 417.8804277 keep beeping when not in use?
If you have the 417.88042700 dryer, this is often a symptom of a control panel failure. First though, try resetting the dryer. Unplug the unit (or flip the circuit breaker to off). After 30 seconds to one minute, plug the dryer back in. Press Cancel twice to clear the PF message. Try running a short cycle and see if the unit beeps after the cycle is over.
Also check if you are getting brief power failures. Really short ones might cause beeping without the PF message on the display.
If neither of the above explain the issue, you probably need to check the control board or wiring for a short. A replacement control board is available here: http://www.repairclinic.com/PartDetail/b6p8/Kenmore-Dryer-Main-Control-Board/137008010/1472768?modelNumber=417.88042700 .
I hope this helps.
Aug 09, 2014 | Kenmore Dryers
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
My kenmore dryer keeps beeping the whole time it is running how can I stop the beeping
try to unplug your dryer and hold the start or power button for 10 seconds. then switch on the power and try again. Your power controller may have failed.if this fails but they are aware of the problem and recommends replacing the control card and touch pad.hope this helps
Aug 30, 2009 | Kenmore Dryers
Beeping Sound on Dryer
okay, this same problem happen to kenmore elites, the touch panel will automatically come on and beep even when it suppose to be off, replaced not the board but the touch panel and you will be okay.
Aug 17, 2009 | Frigidaire FEQ1442ES Electric Dryer
Keeps beeping
stuck door switch or mis coommunicating control board
Dec 19, 2008 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
197 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
