Question about Sony RDR-VX500 DVD Recorder/VCR
DVD Drive Replacement VX-500
The DVD drive isn't reading any discs, and I have tried several. It used to play & burn fine. I am sure it is not faulty discs or a dirty lens. Can you simply buy a regular computer internal DVD drive and replace it in the recorder unit? And if so are there any special instructions to do this, or websites that show you how? Thanks in advance!
Thanks for this cool solution!
It's working - from the first tried!
Posted on Jun 18, 2013
  • 97 Answers
SONY does not use off the shelf drives for their units. Newer recorders are not even built by them. They are rebadged Lite-On and sometimes LG. If this were a Pioneer, you could get a new Pioneer PC drive recorder to replace it with. SONY wants you to buy a new unit and I can bet it will be too costly for you to obtain the SONY drive. Solution, do not buy SONY, they do not care about their customers.
Posted on Mar 31, 2007
Some of the dvd players you can replace the deck with a dvd drive.If it has the power and normal computer dvd rom plug you can replace it and it should work.It is easy to do.just plug the old unit out and the new one in.
Posted on Mar 29, 2007
Display Reads - No Read or UNSUPPORTED when using DVD
If you cant play a real dvd in it, the laser is prob out of allignment or broken, if its just dvd that you burned, try changing disc type, there is +R and -R , also if that does not work try a different program to burn discs ? good program is convert X to dvd, not free, unless your good at torrents :)
Jul 11, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Bad DVD message
I'm assuming that you made sure the disc is free of smudges and dust. It's possible that between now and the last time you tried, you ended up with a dirty lens - try another disc to be sure it's only this one that has problems. If another DVD has trouble too, you need a lens cleaner kit.
Aug 11, 2008 | Cyberhome CH-DVD 300 DVD Player
My dvd recorder will play but not burn anything at all
your laser lens of the dvd doesnt work thats why it doesnt read the disc the same thing was happening to me so u can open it and look if the thing where the laser lens is at is not stuck or your lens they wont work anymore.
Apr 30, 2010 | Cyberhome DVR 1600 DVD Recorder
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Pionner DVR-540H-S no longer plays DVD's
little,
good day, true it's not advisable to use disc cleaner for it may also damage or scracth the optic lens inside.Possibly the optic lens of your player is either dirty caust by dust or faulty. but let's do hope it's only dust related and the only thing you can do now is to open and unscrew the upper cover of your player. Get a soft cotton buds, after dismantling the upper cover locate the optic drive lens and clean the lens by wipping it gently in circular direction. then try to play some DVD.
cheers,
mark
Feb 01, 2009 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Will not read DVD discs.
It looks like you have a lens problem, DVD and CD use a different error correction and different track format.
A dirty lens can read CD but not DVD.
Tru first using a lens cleaner like this ones:
If it does not work you can try cleaning the lens directly with cotton and isopropyl alcohol, you will need to undo the screws at the button and to take apart the cover. Unplug power when doinfg this.
If it still does not work, since you aready reinstalled the firmware, the lens may be faulty.
You can order the lens pickup from factory and replace it.
Sep 02, 2008 | LG Computers & Internet
Won't play dvd
Most DVD players that would not play a disc even with a known good disc inside signifies that the llaser eye/lens is not reading the disc. This could probably be attributed to:
1. dirty, damaged, inverted, blank, un-finalized burned CDs or DVDs;
2. defective, weak, dirty/dusty burned-out laser eye/lens;
3. defective slider shafting (where the laser eye's carriage moves) or some other components.
A few things you can try:
1. Use a CD cleaner (readily available from most computer shops);
2. use a can of compressed air and blow through the inside of the loaded disc area;
3. gently tap on the top cover where you estimate the reading/laser eye/lens would be;
4. gently press on the tray door once the disc is loaded.
Should this not be corrective, perhaps your best bet would be to seek the services of a qualified professional such as those in a Service Center. Alternately, your friendly neighborhood electronic shop should do just fine.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kindest regards.
Feb 09, 2008 | Daewoo DVN8100N DVD Player
Problems with playing discs
There are several causes for this problem.
1) Faulty DVD drive. Most drives have a dual laser, one for CD, and one for DVD. Check the player with both CD, and DVD. If it reads one and not the other, then it is most certainly a faulty laser. The laser assembly or whole mechanism will need changing.
2) Dirty or dusty lens. If the unit is kept in a dust environment, dust and dirt can be drawn into the machine by the fan. Try using a DVD lens cleaner. If this doesn't work try a CD lens cleaner. (Dual laser - see 1))
3) Condensation. Condensation can build up on the laser lens if the unit is kept in a humid environment. Also, this can be caused by a cold environment. In this case, condensation forms as the unit warms up. In either case, leave the unit in a warm dry environment for an hour.
Jan 12, 2008 | Philips LX3600D System
Can not play dvds
Nov 10, 2007 | Philips HTS3500S System
DVD problem
Have you tried several DVDs? Maybe it doesn't read some types of DVDs.
Mar 21, 2007 | Dell Dimension 4600 PC Desktop
Sony RDR-VX500 DVD Recorder/VCR Logo
291 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
