Question about HP LaserJet 5550 Printer
HP 5500 51.2M ERROR
I have HP 5500 51.2M ERROR this error on my control pannel
  • Anonymous Mar 19, 2014
    hp5500ps error
Perform cold reset. How? http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl12227&prodTypeId=18972&prodSeriesId=25470&locale=en_US
Posted on Dec 11, 2009
    Sniper:
  • 121 Answers
Laser error Magenta cart.
Turn unit off and back on if error remains it is usually the laser scanner for the color indicated.
you can reseat the cable from the scanner to the board and see if that helps
Posted on Mar 04, 2009
51 2M erorr or hp printer 5500
Posted on Jun 17, 2009
3 Suggested Answers
The Machine
  • 788 Answers
SOURCE: hp printer problems
Error codes starting with 13 usually indicate paper jams. Open all the doors on the printer and remove any removable modules and check for stuck paper.
Posted on Jan 11, 2008
Slasher_X
  • 767 Answers
SOURCE: i have HP 5500 51.2M ERROR this error on my
Head over to HP support fo a list of errors and their fixes
Posted on Mar 09, 2011
I have a hp envy m6 cant find the control pannel
press window key and r key together, this is run command , a dialog box will open then simply type control panel in the box and u r done . control panel will open automatically.
Nov 20, 2012 | Computers & Internet
My hp w1907 monitor flashes an "input signal out of range. change settings to 1440x900 - 60Hz" notification. How do I change the settings?
Start>Settings>Control Pannel
Go to control pannel and select the graphic diver depending on ur monterboard.
Select the setting u want and press ok.A dialog box will ask u to confirm if u want the current resolution.Press ok and there u have it.
Jun 07, 2011 | HP Computers & Internet
Hi, Neither the built-in mike nor the one on my headset are working. How do I un mute the mic? Dennis
Go to controll pannel /all controll pannel items /sound/then the next tab recording and check the proper mic and select and configure down and do the configuration.
Dec 14, 2010 | HEWLETT-PACKARD HP Pavilion DM4-1160US...
Hp color laser jet printer is displaying error 59.co on the display pannel
Developing disengaging motor error
. Run the component test to verify that
the print developing disengaging
motor is working correctly.
. Reconnect the connectors J468 and
J1020 between the developing
disengaging motor and the DC
controller PCB.
. if motor is not rotating Replace the developing disengaging
motor.
or
problem due to cairtage leaver lock cairtages not engage properly i hv found max problem of this leaver it found damaged due to improper opening the doorpls follow above steps if problem not resolved then call hp engr for 4th step
May 14, 2010 | HP LaserJet 4700 Printer
HP color laser jet printer is displaying error 59.co on the display pannel
The "developing disengaging motor" has problems. You need a technician. Try running the component test from the control panel. Select the disengaging motor and test it. Maybe it'll start working after the test!
Mar 25, 2010 | HP LaserJet 4700 Printer
Has the hp compaq nc 6120 got built in wireless or
click on to start go to control pannel and in control pannel look for network connection in network connection look for wireless network right click and then click on to enable and the wireless would get enable
Jul 22, 2009 | Computers & Internet
Cannot print using my HP C4150 all-in-one
go to start then to control pannel then go to printers and put your printer'sname in the box
Jan 17, 2009 | HP Photosmart C4150 All-In-One InkJet...
HP Printer will no longer scan
Hi Keithcarrol
Please do the following
1. Go to Control Pannel then sellect Add/Remove Programs and uninstall all HP Software.
2. Disconnect all Prinetrs
3. Go to Control Pannel then sellect Printers and Faxes make sure there is no Printers in there if there is delete them
4. Install Psc 2210 software and follow instructions on when to connect printer.
Dec 15, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp printer problems
Jan 11, 2008 | HP Color LaserJet 2600n Printer
HP LaserJet 5550 Printer Logo
4,548 people viewed this question
Seeker5211
Seeker5211
