Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
42 inch Craftsman carburator not getting any gas. You can spray quick start and will will fire. Does gas from tank gravity feed to filter?
  • cmsurfnut May 03, 2009
    I do have wire under carb
    spary start then shut down
  • Al Perry May 11, 2010
    Do you have an electrical wire going to the bottom of the carburator? Is there fuel to the carburator from the tank?
Put a small clamp on the fuel filter. Take the fuel filter off. Invert the direction of flow. Blow it out with low pressure. Reinstall.
Alternate-
Buy a new clear bowl fuel filter. New gas additives add to the problem of crud in gas tank/fuel system. Dissolves old crud in gas tank.
Posted on Jun 03, 2009
    Novelist:
  • 126 Answers
Gas tank gravity feeds fuel to the carb. if you pull the fuel line from the carb, fuel should flow out of the tube. if it does not, then either the vent hole on the gas cap is plugged or there are contaminents at the bottom of the gas tank preventing fuel from flowing into the fuel line.
Posted on Jan 29, 2009
Lawn mower will not start it's a craftsman model number 917.9998c
First check and see if your coil has spark remove plug spray gas into cylinder try to start if it fires you have a fuel deivery problem replace coil if it does not fire if it does you have a fuewl problem check filter if ok rebuild the carburator
Mar 12, 2017 | Craftsman Garden
Gas tank
Un hook the gas line,.drain all gas out.Get a rag,stuff it in gas tank.Get a 1/2 inch dowl.About 7 inches long.Stir the rag inside gas tank.Take rag out,put new rag in tank Swish around inside tank.Get as much as you can out of tank.when you get it Quite clean,add /spray Carb cleaner into the tank.And some gas,drain again until its clean.Only enough gas to swish around.You can see inside tank with a mirror.
Jul 24, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
Cant start my craftsman leaf blower
Chances are your carburator has dirt in it.
It doesn't take much to clog those little carbs.
Empty the gas tank and clean it.
Purchase a can of small engine carburator cleaner. Comes in a spray can for about $5 at Home Depot or Lowes.
Remove the carburator and disassemble it.
Soak the body in clean gasoline for about 15 minutes if you can, agitate it to help the gas disolve any clogs.
Clean the ports with the spray cleaner to blow out any debris.
Reassemble and remount the carb.
Remove, clean and gap the spark plug
Refuel the gas tank with new clean gas
May 16, 2011 | Craftsman Garden
I have a 16hp Honda engine on my Craftsman riding mower and it will not fire. I have checked the plugs, carburator, switch on seat. no luck!
just trying to grasp the situation here: I am assuming that it will not fire means it is cranking but not starting.... pull the plugs and have them laying where you can see if they are sparking, if they are then the coil is good, this means that the gas is not getting to the plugs, you will need to disconnect the gas line on the fuel filter, gas should come out of the hose, if not then the line or the bottom of the tank is clogged, if it does then hook it back up and disconnect the line after the filter, check for gas, if none the filter is clogged, if yes then disconnect the gas line from the carburetor, same as before. Hope this helps Tim if the situation is different then post and if I am still here I will answer
Apr 17, 2011 | Craftsman 175 hp 42" Lawn Tractor (CA) ()
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 19.5 42inch deck riding mower and no gas
just wanting to know where the gas line and air filter is on a craftsman 19.5 hp twin 42 hydro is
Sep 30, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mower engine cuts out at exactly 1/2 full tank of gas
When that happens loosen the fuel cap and see if it stays running. If this is a gravity feed system make sure you have the correct fuel filter on it,the clear paper filters can allow vapor lock to happen,put the small briggs and stratton filter in it,which has a small chamber and a stainless screen.Also make sure there is no excess fuel line that would cause a dip or a high spot for a vapor lock to occur.
Aug 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 917.270662 starts with starter fluid but won't stay run
the float in the carburator is stuck shut not opening alowing fuel to enter engine
Jun 07, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
586 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
