Question about Powerware 9120 UPS System
Control board for 9120 6kva - Powerware 9120 UPS System
  • 3 Answers
Dear " youlooklikea " is the control board avaliable
Posted on Jul 09, 2010
  • 3 Answers
710-12102-0X - PCBAS 9120 5-6KVA CNTL-1112NN - £107.67 + delivery + VAT from the Manufacturer - Eaton Power Quality Ltd
Posted on Jun 17, 2009
  • Border Sep 15, 2013
    youlooklikea, I have a problem with a Powerware 9120 displaying Batt Disconnected. They are in fact new batteries that were installed a week ago. The unit was placed back into service and appeared to be working fine. It took a week to shutdown again on Batt Disconnected. I have checked the set up on the unit to find it is in free run mode, however the only parameter that does not apper corrdct is the Bypass Go which is set to ON and I cant get it to OFF?. I have checked the 2 x hrc fuses inside the unit and they appear ok however the unit will not powerup and ppppppppppppppppppppppp appears across the screen following switch on. The charger ouput voltage is at 265 volts the battery is at 127 volts.
Is There Any Changes in the Board Software Version After a Service Board Is Replaced?
fter a service board is replaced, the control board checks and determines the software of the new service board.
1. If the IO board package file contains the new service board, the control board updates the software of the new service board to that of its own.
If the new service board supports the anti-downgrade function and the control board software is within the anti-downgrade version range, the new service board runs with its default software.
If the new service board supports the anti-downgrade function but the control board software is not within the anti-downgrade version range, the control board updates the software of the new service board as that of its own.
If the IO board package file does not contain the new service board, the software of the new service board is loaded to the IO board package file of the control board.
Huawei GPBD Board Thunder link com
Dec 09, 2016 | Televison & Video
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Which way do the connectors go on the control board?
Hello Verlaine;
My name is Peter. I am a retired field service refrigeration technician.
Please let me help you.
You received the new control board in a silver anti-magnet bag. Hopefully, you have not removed the control board without grounding yourself first. You ground your self by rubbing your hands over something that is steel. Static electricity will kill the board.
The connectors on a control board are proof. Each connector is designed to fit a specific plugin.
After you have located the control board, refrigerator unplugged,
Usually, a 10" x 8" cover plate on the back of your refrigerator.
Ok, you have removed the control board cover plate. You will see the control board is mounted on white pins. On these pins are 2 legs protruding. With one hand squeeze the first pin, Pushing the pin legs in. With the other hand pull the control board forward toward you. Go around the board until the board is free.
Systematically, with the new board, take one connector off the old board and put it one the new board. Repeat this until all of the connector are on the new board. Push the new board on the white pins to secure.
Why do you think your problem is a control board? Send me the model number of your refrigerator and tell me what the issue is.
The manufacturer recommends a surge protector. All appliances like you computer with control boards should have a surge protector. You can get individual wall socket surge protector at Lowes or Home Depot for about $15.00.
Nov 11, 2014 | Refrigerators
Sir i have a problem my rich 7650 give 601 code i change mane board but position same
SC601 - Communication error (main control board and optics control
board)
Definition: [level: D]
The main control board does not communicate with the optics control
board.
Possible causes:
· Main control board defective
· Optics control board defective
· Harness defective
May 08, 2014 | Office Equipment & Supplies
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
Code E 70 on a 6000
Here are all the Fault Codes on the 6000/7000 but i dont see a E70 on here are you sure?
Failure code Fault condition Check
E11 Fill time to long. Refer to test (1).
E23 Drain pump relay on control board failed. Replace control board orwire.
E24 Drain pump relay on control board failed. Replace control board orwire.
E36 Control board problem. Replace the control board.
E41 Control board thinks the door switch is open. Refer to test (7).
E43 Board communications problem. Replace the control board.
E44 Board communications problem. Replace the control board.
E45 Board communications problem. Replace the control board.
E46 Board communications problem. Replace the control board.
E47 Board thinks the door PTC circuit is open in spin. Refer to test (7)
E48 Board thinks the door PTC circuit is closed. Refer to test (7)
E56 Highmotor current. Refer to test (9)
E5A High temperature on heat sink. Test first if bad replace
E5B High temperature on heat sink. Replace the speed control
board.
E5C High temperature on heat sink. Replace the speed control
board.
E68 Current leakage to ground on heater or fuse opened. Refer to test (14).
E74 Wash temperature does not increase. PlaceNTC in correct position.
E76 NTC temperature for the cold water valve over the limits. Hot and cold water hoses
switched.
E82 Console control problem Replace the control board.
E83 Console control problem Replace the control board.
E91 Selector LEDs do not light up Refer to test (16)
E93 Console control problem Replace the control board.
E94 Console control problem Replace the control board.
E95 Communication error. Replace the control board.
E97 Console control problem Replace the control board.
E98 Console control problem Replace the control board.
EB1 Incoming power frequency out of limits. Refer to test (15)
EB2 Incoming line voltage above 130 VAC. Check voltage at the outlet.
If below 130 VAC replace the
control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at the outlet.
If above 90 VAC replace the
control board.
EF2 Tomuch soap. Advise customer to reduce
the amount of soap they are
using.
EBE Console control problem Replace the control board.
EBF Console control problem Replace the control board.
EF5 NTC temperature for the hot water valve over the limits. Hot and cold water hoses
switched.
May 08, 2008 | Frigidaire Affinity ATF7000E Front Load...
Washing machine error code on Frigidaire ATF6000E
No E20 on that model# Heremis a list of the codes
board.
board.
switched.
Mar 29, 2008 | Frigidaire ATF6000ES Front Load Washer
I'm getting a SC 558 error
SC558 Abnormal zero
cross signal
- Timing & Condition -
Zero cross signals
generated within certain
period do not reach a
predetermined target
value.
• Poor connections
• Blown fuse
• Defective AC drive board
board
board
1. Make sure the following are connected
properly:
• CN212 and CN229 on the I/O control
board
• CN303 on the main control board
• CN7 on the AC drive board
2. Check the current through the signal lines
in the above harnesses.
3. Replace the fuse (FU101) if it is blown.
4. Test the AC drive board, I/O control
board, or main control board by checking
the signal line at each pin.
[Signal Check]
• Zero cross: CN7-5 on the AC drive board/
CN229-6, TP216, or CN212-B8 on the I/O
control board/CN303-B4 or TP120 on the
main control board
Any problems get back to me
Than You
Mar 11, 2008 | Ricoh 6513 Copier
Powerware 9120 UPS System Logo
432 people viewed this question
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Jax Planet
Jax Planet
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
