Question about Pentax Optio M20 Digital Camera
Camera won't stay on.
Put new batteries in the camera but when I push the power button it turns on and right back off.
  • 1 more comment
  • cwalker360 Dec 17, 2008
    I cleaned the unit where the battery goes and it still turns right back off. Do you have another solution?
    No, I have checked that several times.
    No, that didn't work either. It still turns right back off.
  • Pentax Master
  • 19,396 Answers
That means that there is a short inside (maybe on battery or power wirings), camera main logic board detects it and camra shuts down after one second.
Cameras can go in protect mode like any other modern defective device, when a problem of this kind is detected.
the problem can also be caused by a power on switch stuck on position, or any other switch or control being stuck or shorting out.
Posted on Dec 17, 2008
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls bear with me and address back the battery contacts.
Scrape (not only clean), there would be corrosion that normally cleaning could not remove, scraping exposes the bare metal contacts;
  • at times these battery contacts may have to be bent or stretched a little bit more so as to exert more pressure thus ensuring full contacts with the batteries;
  • jar the camera back into action by thumping it against the palm of your hand. Of course this is not a technical solution but has been proven in some other cases.
Good luck and Thank you for using FixYa. Happy Holidays.
    Sergeant:
    Champion:
  • 258 Answers
There's a problem on that switch
  • 837 Answers
Be sure to use GOOD batteries .. no cheapies .. many times the off brand cheap batteries just don't work
    Sergeant:
    Novelist:
  • 327 Answers
Its not the battery problem its the circuit short problem in the device for sure and needs reparing.any of the components is got loosed on the circuit and it needs soldering to make it proper the cost will be negligible .give it a tey.
thanks.
    President:
  • 2,110 Answers
Try to power on camera after removing the memory card...bcoz memory card might have some problem..
  • 136 Answers
Could the batteries be inserted incorrectly?
Posted on Dec 16, 2008
    Master:
  • 479 Answers
The socket where u insert the batteries clean that and then try.or also it could be the internal circuit getting heated and power goes off.this issue.
Pentax optio w80 waterproof digital camera won't turn on
I had the same problem. I checked the voltage first to ensure it was greater than 3.7V (some batteries were not). I left the door open and pushed the battery down and pressed the button and it powered up. Seems to be a problem with the contacts. I put about 6 layers of duct tape on top of the battery to cause the door to push it down and now it works.
Feb 21, 2013 | Avianne & Co Pentax Optio W80 Waterproof...
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
I'll push the power button and the little green light flashes it beeps and the lense comes out just a tiny bit but then in stops goes back in and beeps twice and it's still off. Is there and...
First check the battery. Charge the battery to full condition or change with new battery and try to turn on your camera.
Or you can put off all batteries and memory card, wait for a moment, then put in again and turn on your camera.
Hope this help
Feb 09, 2011 | Casio EXILIM 10.1-Megapixel Digital Camera...
We have a relatively new Sanyo vpc-s120, and have just tried to change the batteries for the first time. I have tried several sets of both alkaline AND rechargeable (both of which are recommended in the...
When You Turn On Your Camera Push the Menu Button then Push The Little Flower Which Is The Down Arrow in The Square box on the Camera It Should Take You to The Option Menu, Now Press the Video/time Mode Should be On Your Right, Next Press the Flower Button Which is Down 7times Then Press Set Which is The Middle Button In The Square Then Select Which Battery You Want To Use The Rechargeable Batteries Or So Much Better and Last Longer. Hope That Solved Your Problem and Have A Nice Day.
Oct 11, 2010 | Cameras
Power on n off
sounds like a battery power problem or problem with the terminal of the camera ; you know the point where the battery meets the camera.
I would recommend a service center
May 31, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Help??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the above didn't work, then consider the following:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 15, 2008 | Canon PowerShot A620 Digital Camera
Camera wont turn off
Remove the battery. The same thing happened to mine and once I put the battery back it worked fine.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
Pentax Optio M20 Digital Camera Logo
18 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
