Question about Garmin nuvi 200W GPS Receiver
Battery I just bought my unit, maps are loaded in, should I let battery go completly dead before plugging it into car. Does battery build up a memory.
  • Garmin Master
  • 2,130 Answers
No, the lithium-Ion batteries do not have a memory issue like Ni-Cad batteries. Use the car adapter whenever you like.
- Jim
SHARCNET-USA
Posted on Dec 15, 2008
I bought this devise in USA last year where it worked very well.I fished it out the other day but it doesn't work here why?
When you mean does not work, does the unit power up or is it plain dead? If it does not turn on, then you will need to troubleshoot or send out for repair.
If it turns on, but does not provide you with maps, you need to load maps for Australia as you currently have US maps loaded on the device.
Google search for Australia maps for your unit, or contact Garmin customer service.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
Gpsmap 180 firmware corrupt
It sounds like it has lost its memory battery. Usually you
would get a "memory battery low" message as it is on its
way out but you don't mention that so perhaps it has
completely failed.
The battery is rechargeable - if you leave it switched off
and loaded with a fresh set of alkalines for a few days it
may recover. If not contact Garmin as they have replaced
many memory batteries free of charge even out of warranty.
Oct 30, 2007 | Garmin GPSMAP 430 GPS Receiver
Two brand new Hitachi BSL1815X Lithium Batteries won't recharge (UC18YGSL charger and DS 18DSAL drill)
These batteries have big problems that Hitachi doesn't address very well. Unlike NiCad batteries, Lith-Ion ones must be periodically used and recharged to retain their battery functions, i.e. if they have been sitting on the shelf at a store for an extended period of time, chances are they will be dead when bought and will not accept a charge. If they go dead i.e. no little red light on the charger when you plug the battery unit in...it's basically junk.
If you can return them or exercise the warranty do so. If / when you get new ones DO NOT completely discharge them like you would NiCads. Lith-Ion batteries do not have the "battery memory" issues that NiCads have which means you don't lose running time if you don't fully discharge the battery unit prior to recharge. Completely discharging before recharge will ultimately kill them. Use the 1815X till almost dead and then charge it. It is also recommended Lith-Ion batteries not be stored fully charged i.e. charge the 1815X fully, drive a couple bolts or screws, remove the battery unit and then put it away. Do not leave battery unit plugged into the tool when you put the tool away. This will discharge and kill the battery unit.
There are non-Hitachi substitute batteries now on the market. I'm guessing the same precautions apply but I don't own one of the replacements so I don't truly know.
The actual batteries in the Hitachi BSL 1815X are Sanyo UR18650SAX lithium ion batteries. Lithium Ion cells aren't all that easy to get commercially because of handling & safety requirements. Not certain if you can take apart the 1815X and swap out the bad Sanyo cells.
Jan 07, 2011 | Hitachi Koki Usa WH18DL Lithium Ion...
Need more memory for complete route, which had before upload
you should be able to buy a sd car to increase the memory.
May 13, 2009 | Garmin Nuvi 660 GPS Receiver
Lost maps by updating
Unit comes with pre-loaded maps. Why update? Maps on DVD is the same copy as it's on the unit.
If you have troubles make sure you're not in Navigation mode when running the update. Update does not like files still in use.
Mar 23, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
255w in a loop - loading maps, then restarts...can't recharge
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
Dec 20, 2008 | Garmin nuvi 255W GPS Receiver
Nuvi 200w map download and sd card
Guys and or ladies... I know that you have to create a folder named "GARMIN" in the sd card so the maps can be recognize. Maybe this solves your problem. Let me know if it works.
BR from Spain,
Carla
May 11, 2008 | Garmin Nuvi 660 GPS Receiver
Which Maps Are Loaded?
From your Where to?/View map screen press on the box wrench to access the settings menu. Once at the settings menu press Map, then press Map Info and you should see that you have City Navigator North America NT v8 or whichever one is loaded.
Nov 30, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin c530
According to technical support, the "glitch" has been fixed with the latest web updater on the Garmin site. In the meantime, you will need to leave the unit unplugged for upto 48 hours to allow the battery die and the unit to get out of its "hang up". Once the battery is completely dead, plug the GPS into a computer (USB) and it should come back to life. Then do the update.
Hope this helps.
Nov 02, 2007 | Garmin StreetPilot c530 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
54 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
