Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
My dishwasher does not wash the dishes
The water enters the dishwasher and leaves the DW at appropriate times but does not circulate thru the DW to wash the dishes
  • 71 Answers
I don't know your brand but It is in the wash pump please give me your model and brand and I will help you
Posted on Dec 14, 2008
  • flyingtarzan Dec 14, 2008
    the pump kit is #8531017 and what is the level of the water as it is running?
    Master:
  • 479 Answers
 Not draining the water out....
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
    Dishes not cleaned properly....
    1. Check the water temperature. Should be 125 to 140 F.
    2. Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
    3. Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
    4. Check the spray arm and pump cover for splits or leaks.
    5. Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
    6. Make sure the dishes are loaded properly, or dishwasher is not overloaded.
    7. Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles.
  • 734 Answers
might be there is sum chocking in the main unit (inside dishwasher).
Thanks
  • futureloginn
    futureloginn Dec 14, 2008
    Go clear your problem through the above link ------
    http://www.repairclinic.com/0088_9_1.asp...
    Thanks
Smeg Dishwasher not circulating water
Sound like the thermostat doesn't know what the water temperature is set at.
It could be the wash pump. Check to see that the float on the bottom of the DW is unstuck by gently picking it up and setting it down { It is shaped like a mushroom and controls the water level in the bottom of the DW }. Did it move freely?
Dec 29, 2013 | Dishwashers
Not rinsing glasses clean
If the glasses are spotty from hard water try a rinse aid like Jet Dry. If they are actually dirty, depending on the brand of DW you may need to rinse them better before putting them in the DW. Not all brands are cerated equally, some do work better then others
Oct 11, 2009 | Dishwashers
After wash cycle and rinsed cycle there were suds
Make certain you do not use dish soap when rinsing the dishes. Make sure you only use DISHWASHER soap when running the DW.
In fact,there is no need to rinse dishes. Remove visible scraps and put them in the DW. If it is a quality DW it will clean your dishes. Do not crowd the dishes in the DW. Most JennAir DW's are quality. Make sure the top rack can get washing action from the bottom spray arm. No pots or other water stopping utensils on the bottom rack.
Oct 06, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Have a 2+year old LG LDF6810ST dishwasher that shows no error codes but is not cleaning like it used to. Have city water, do not leave excess food on dishes when loading, am only using powder after...
Try these things in order:
-Try to use a name brand powder, rather then a generic. Even a small box. I had similar problems with my LG dishwasher when I tried to save money by buying a generic powder. My dishes did not get clean and white marks were left behind on my stainless steel DW liner and the dishes. When you ad the powder, do not over fill the dispenser. Add less than the full dispenser cup and close it. Place some powder in that shallow square indent on the dispenser lid to help the pre-wash cycle. Also, run the water in the sink until hot water runs immediately before you start the DW.
-If, after using Electrosol or Cascade for 2 - 3 loads and your dishes do not come out clean, then I would run a load of dishes without adding the soap. Start the dishwasher and wait for it to fill and begin to wash. Open the door and add one cup of vinegar (white vinegar is fine.) Feel free to ad another cup after the first wash water drains and the second wash water enters and the DW begins the wash cycle again. Run a load of dirty dishes with the soap and check for good cleaning.
-If the problems continue, it is time to remove the filter assembly by removing the 9 silver phillips screws from the filter assembly. You will also need to remove the lower sprayer arm by pulling straight up and then out. With a flashlight, inspect the sump area that was hidden by the filter assembly, looking for any debris that has jammed into anywhere down there. Watch out for broken glass as you feel around. Reassemble and test with a load of dirty dishes.
The poor drying may be caused by not keeping the rinse aid re-filled. Check that first.
Also, these water and energy conserving dishwashers actually use the "dirt" from the dirty dishes to help clean the dishes during the first two wash cycles. Simply clear the big chunks off the dishes and put the dishes in the DW.
Please report back what you find or if you have more questions. OK?
Aug 12, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishes not cleaned
When ever I hear of a dishwasher "suddenly" not cleaning properly, with spots on the glassware and soap not dissolving:
-If the spots are white patches, you can suspect the DW detergent powder. Go buy a name brand of detergent powder and I bet you will see a dramatic improvement. You may need to run a cycle or two with white vinegar added (up to two cups added after the DW starts, fills and begins to wash.)
-If the spots are a film / slime, you should suspect that the heating element. For the dW to be effective cleaning and rinsing clear,the DW needs to raise the water temp during the ~wash~ cycle (after the detergent dispenser has magically opened. After the heating element has been replaced, you will see an immediate improvement.
-If you had reported food debris sticking to dishes, (which you didn't), the first thing to do is clear the holes in the wash arms, then open the sump area , remove the filter assembly and inspect closely with a flashlight to locate blocking debris. (watch out for broken glass!) Inspect the impeller and make sure it is not damaged. If after assembly, the cleaning is still poor, it is time to replace the wash pump / motor assembly.
Good Luck! Ask more questions as needed!
Mar 30, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Frigidaire FDB635RBB heat wash/heat rinse
Most DW today take a minimum of 90 minutes. Run the hot water from the sink until it gets hot, then start the DW, this will shorted the first wash cycle. It is not uncommon for the DW to run 2hrs or more based upon the water temperature entering the DW and the soil level of the items in the DW.
May 29, 2008 | Frigidaire 24 in. FDB635RF Built-in...
Zanussi DE 6554 Dishwasher
Wash the dishes by hand and view them again 1 hour later. If the dishes are still cloudy it's too late you have been running in hard water for years and etched the dishes. Salt only regenerates the Xeolite beads inside the DW. They collect minerals until they can no longer hold more, then the DW washes the minerals off the beads with the salt. Check if the DW is set correctly to the appropriate water hardness of your town. READ THE OWNERS MANUAL. PS> 1. You can't use regular salt. 2. Is the salt dry? Salt must be added into water so it creates solution (brine).
May 05, 2008 | Dishwashers
Bosch Exxcel Auto Option/Detergent tablet does not dissolve?
It seem that your DW drain it's water by syphon action. Check if the drain hose is properly installed as a U shape; otherwise the DW can drain itself at any time, leaving the soap undissolved .
Nov 16, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
146 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
